/*** Author: N@v* Version: 0.0.1* Date: 11/01/2012** Description:* This script permits to calculate the SSE measure of a given clustering coming out from a centroid-based clustering algorithm.** Input:* input[0]: the example set of the clustering* input[1]: the example set of the centroids* input[2]: the cluster model of the cluster operator** Output:* The SSE value of the clustering will be displayed in log consolle.**/import com.rapidminer.operator.clustering.ClusterModel;import com.rapidminer.operator.clustering.Cluster;ExampleSet clusteringSet = input[0];ExampleSet centroids = input[1];ClusterModel clustering = input[2];Double sum = new Double(0);centroids.remapIds();TreeMap<Integer,Example> centroidMap = new TreeMap<Integer, Example>();for (Example centroid : centroids) { String key = centroid.getValueAsString(centroid.getAttributes().get("cluster")); key = key.substring(8); Cluster cluster = clustering.getCluster(Integer.parseInt(key)); if (cluster.getNumberOfExamples() == 0) { continue; } else { Collection<Object> idsList = cluster.getExampleIds(); clusteringSet.remapIds(); for (Object id : idsList) { Example example = clusteringSet.getExampleFromId((Double) id); distance = new Double(calculateEuclideanDistance(centroid, example)); sum += distance*distance; } }}operator.logNote("SSE: " + sum);Double calculateEuclideanDistance(Example a, Example b){ Attribute[] atts = a.getAttributes().createRegularAttributeArray(); Double sum = new Double(0); Double dist = new Double(0); for (Attribute att : atts){ String attStr = att.getName(); Double aValue = new Double(a.getValue(a.getAttributes().get(attStr))); Double bValue = new Double(b.getValue(b.getAttributes().get(attStr))); Double difference = new Double(aValue - bValue); sum += Math.pow(difference,2); } dist = Math.sqrt(sum); return dist;}
