<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.015" expanded="true" name="Process"> <process expanded="true" height="280" width="681"> <operator activated="true" class="retrieve" compatibility="5.1.015" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Labor-Negotiations"/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="5.1.015" expanded="true" height="76" name="Rename by Replacing" width="90" x="179" y="30"> <parameter key="include_special_attributes" value="true"/> <parameter key="replace_what" value="-"/> <parameter key="replace_by" value="_"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.1.015" expanded="true" height="76" name="Generate Attributes" width="90" x="313" y="30"> <list key="function_descriptions"> <parameter key="wage_inc_3rd_replacement" value="if(missing(wage_inc_3rd),if(duration>2,duration-10,duration/3),wage_inc_3rd)"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.015" expanded="true" height="76" name="Select Attributes" width="90" x="447" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="wage_inc_3rd"/> <parameter key="invert_selection" value="true"/> </operator> <operator activated="true" class="rename" compatibility="5.1.015" expanded="true" height="76" name="Rename" width="90" x="581" y="30"> <parameter key="old_name" value="wage_inc_3rd_replacement"/> <parameter key="new_name" value="wage_inc_3rd"/> <list key="rename_additional_attributes"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
