<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.015" expanded="true" name="Process"> <process expanded="true" height="251" width="547"> <operator activated="true" class="generate_nominal_data" compatibility="5.1.015" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"> <parameter key="number_of_values" value="2"/> </operator> <operator activated="true" class="multiply" compatibility="5.1.015" expanded="true" height="94" name="Multiply" width="90" x="179" y="30"/> <operator activated="true" class="filter_examples" compatibility="5.1.015" expanded="true" height="76" name="Filter Examples (2)" width="90" x="313" y="120"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="att1 = value2"/> </operator> <operator activated="true" class="store" compatibility="5.1.015" expanded="true" height="60" name="Store (2)" width="90" x="447" y="120"> <parameter key="repository_entry" value="value2_data"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.1.015" expanded="true" height="76" name="Filter Examples" width="90" x="313" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="att1 = value1"/> </operator> <operator activated="true" class="store" compatibility="5.1.015" expanded="true" height="60" name="Store" width="90" x="447" y="30"> <parameter key="repository_entry" value="value1_data"/> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Filter Examples (2)" to_port="example set input"/> <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Store (2)" to_port="input"/> <connect from_op="Store (2)" from_port="through" to_port="result 2"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Store" to_port="input"/> <connect from_op="Store" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
