Hi all
I successfully installed RA, and have had it running for sometime.
Today however I went to start it, but could not get it to run. Ive tried restarting the windows service several times, but without success.
Any help is appreciated.
The output from running the run.bat file is:
21:46:31,475 INFO [BeanInstantiatorDeployerBase] Uninstalled org.jboss.ejb3.ins
tantiator.impl.Ejb31SpecBeanInstantiator@2ce3c6e7 from MC at org.jboss.ejb.bean.
instantiator/RapidAnalytics-CE-1.1.014/RapidRepositoryEJB/UserCreationEJBImpl
21:46:31,478 ERROR [AbstractKernelController] Error installing to Real: name=vfs
//C:/RapidAnalytics/1.1/server/default/deploy/RapidAnalytics-CE-1.1.014.zip st
ate=PreReal mode=Manual requiredState=Real: org.jboss.deployers.spi.DeploymentEx
ception: Error deploying RapidRepositoryEJB.jar: de/rapidanalytics/entity/Reposi
toryException
at org.jboss.ejb3.deployers.Ejb3Deployer.deploy(Ejb3Deployer.java:194) [
:6.0.0.Final]
at org.jboss.ejb3.deployers.Ejb3Deployer.deploy(Ejb3Deployer.java:60) [:
6.0.0.Final]
at org.jboss.deployers.vfs.spi.deployer.AbstractSimpleVFSRealDeployer.de
ploy(AbstractSimpleVFSRealDeployer.java:56) [:2.2.0.GA]
at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.i
nternalDeploy(AbstractSimpleRealDeployer.java:62) [:2.2.0.GA]
at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(
AbstractRealDeployer.java:55) [:2.2.0.GA]
at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(Deployer
Wrapper.java:179) [:2.2.0.GA]
at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(Deployer
sImpl.java:1832) [:2.2.0.GA]
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFi
rst(DeployersImpl.java:1550) [:2.2.0.GA]
rst(DeployersImpl.java:1603) [:2.2.0.GA]
at org.jboss.deployers.plugins.deployers.DeployersImpl.install(Deployers
Impl.java:1491) [:2.2.0.GA]
at org.jboss.dependency.plugins.AbstractControllerContext.install(Abstra
ctControllerContext.java:379) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.dependency.plugins.AbstractController.install(AbstractContr
oller.java:2044) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.dependency.plugins.AbstractController.incrementState(Abstra
ctController.java:1083) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.dependency.plugins.AbstractController.executeOrIncrementSta
teDirectly(AbstractController.java:1322) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.dependency.plugins.AbstractController.resolveContexts(Abstr
actController.java:1246) [jboss-dependency.jar:2.2.0.GA]
actController.java:1139) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.dependency.plugins.AbstractController.change(AbstractContro
ller.java:939) [jboss-dependency.jar:2.2.0.GA]
ller.java:654) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.deployers.plugins.deployers.DeployersImpl.change(DeployersI
mpl.java:1983) [:2.2.0.GA]
at org.jboss.deployers.plugins.deployers.DeployersImpl.process(Deployers
Impl.java:1076) [:2.2.0.GA]
at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeploye
rImpl.java:679) [:2.2.0.GA]
at org.jboss.system.server.profileservice.deployers.MainDeployerPlugin.p
rocess(MainDeployerPlugin.java:106) [:6.0.0.Final]
at org.jboss.profileservice.dependency.ProfileControllerContext$Delegate
Deployer.process(ProfileControllerContext.java:143) [:0.2.2]
at org.jboss.profileservice.dependency.ProfileDeployAction.deploy(Profil
eDeployAction.java:151) [:0.2.2]
at org.jboss.profileservice.dependency.ProfileDeployAction.installAction
Internal(ProfileDeployAction.java:94) [:0.2.2]
at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction
(InstallsAwareAction.java:54) [jboss-kernel.jar:2.2.0.GA]
(InstallsAwareAction.java:42) [jboss-kernel.jar:2.2.0.GA]
at org.jboss.dependency.plugins.action.SimpleControllerContextAction.sim
pleInstallAction(SimpleControllerContextAction.java:62) [jboss-dependency.jar:2.
2.0.GA]
at org.jboss.dependency.plugins.action.AccessControllerContextAction.ins
tall(AccessControllerContextAction.java:71) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.dependency.plugins.AbstractControllerContextActions.install
(AbstractControllerContextActions.java:51) [jboss-dependency.jar:2.2.0.GA]
at org.jboss.profileservice.dependency.ProfileActivationWrapper$BasicPro
fileActivation.start(ProfileActivationWrapper.java:190) [:0.2.2]
at org.jboss.profileservice.dependency.ProfileActivationWrapper.start(Pr
ofileActivationWrapper.java:87) [:0.2.2]
at org.jboss.profileservice.dependency.ProfileActivationService.activate
Profile(ProfileActivationService.java:215) [:0.2.2]
(ProfileActivationService.java:159) [:0.2.2]
at org.jboss.profileservice.bootstrap.AbstractProfileServiceBootstrap.ac
tivate(AbstractProfileServiceBootstrap.java:112) [:0.2.2]
at org.jboss.profileservice.resolver.BasicResolverFactory$ProfileResolve
rFacade.deploy(BasicResolverFactory.java:87) [:0.2.2]
at org.jboss.profileservice.bootstrap.AbstractProfileServiceBootstrap.st
art(AbstractProfileServiceBootstrap.java:91) [:0.2.2]
at org.jboss.system.server.profileservice.bootstrap.BasicProfileServiceB
ootstrap.start(BasicProfileServiceBootstrap.java:132) [:6.0.0.Final]
ootstrap.start(BasicProfileServiceBootstrap.java:56) [:6.0.0.Final]
at org.jboss.bootstrap.impl.base.server.AbstractServer.startBootstraps(A
bstractServer.java:827) [jboss-bootstrap-impl-base.jar:2.1.0-alpha-5]
at org.jboss.bootstrap.impl.base.server.AbstractServer$StartServerTask.r
un(AbstractServer.java:417) [jboss-bootstrap-impl-base.jar:2.1.0-alpha-5]
at java.lang.Thread.run(Unknown Source) [:1.7.0_01]
Caused by: java.lang.NoClassDefFoundError: de/rapidanalytics/entity/RepositoryEx
ception
at java.lang.Class.getDeclaredMethods0(Native Method) [:1.7.0_01]
at java.lang.Class.privateGetDeclaredMethods(Unknown Source) [:1.7.0_01]
at java.lang.Class.getDeclaredMethods(Unknown Source) [:1.7.0_01]
at org.jboss.ejb3.interceptors.lang.SecurityActions$1.run(SecurityAction
s.java:43) [:1.1.3]
s.java:40) [:1.1.3]
at java.security.AccessController.doPrivileged(Native Method) [:1.7.0_01
at org.jboss.ejb3.interceptors.lang.SecurityActions.getDeclaredMethods(S
ecurityActions.java:39) [:1.1.3]
at org.jboss.ejb3.interceptors.lang.ClassHelper.populateAllMethods(Class
Helper.java:219) [:1.1.3]
at org.jboss.ejb3.interceptors.lang.ClassHelper.getAllMethods(ClassHelpe
r.java:88) [:1.1.3]
at org.jboss.ejb3.interceptors.metadata.BeanInterceptorMetaDataBridge.in
itialise(BeanInterceptorMetaDataBridge.java:246) [:1.1.3]
at org.jboss.ejb3.interceptors.metadata.BeanInterceptorMetaDataBridge.<i
nit>(BeanInterceptorMetaDataBridge.java:138) [:1.1.3]
at org.jboss.ejb3.interceptors.metadata.AdditiveBeanInterceptorMetaDataB
ridge.<init>(AdditiveBeanInterceptorMetaDataBridge.java:48) [:1.1.3]
at org.jboss.ejb3.EJBContainer.initMetaDataBasedAnnotationRepository(EJB
Container.java:1928) [:1.7.17]
at org.jboss.ejb3.EJBContainer.getMetaDataBasedAnnotationRepository(EJBC
ontainer.java:1898) [:1.7.17]
at org.jboss.ejb3.aop.BeanContainer.initialize(BeanContainer.java:191) [
:1.7.17]
at org.jboss.ejb3.EJBContainer.<init>(EJBContainer.java:301) [:1.7.17]
at org.jboss.ejb3.TimerServiceContainer.<init>(TimerServiceContainer.jav
a:86) [:1.7.17]
at org.jboss.ejb3.session.SessionContainer.<init>(SessionContainer.java:
125) [:1.7.17]
at org.jboss.ejb3.session.SessionSpecContainer.<init>(SessionSpecContain
er.java:109) [:1.7.17]
at org.jboss.ejb3.stateless.StatelessContainer.<init>(StatelessContainer
.java:114) [:1.7.17]
at org.jboss.ejb3.Ejb3AnnotationHandler.getStatelessContainer(Ejb3Annota
tionHandler.java:330) [:1.7.17]
at org.jboss.ejb3.Ejb3AnnotationHandler.getContainers(Ejb3AnnotationHand
ler.java:211) [:1.7.17]
at org.jboss.ejb3.Ejb3Deployment.deployElement(Ejb3Deployment.java:759)
[:1.7.17]
at org.jboss.ejb3.Ejb3Deployment.deployElement(Ejb3Deployment.java:710)
[:1.7.17]
at org.jboss.ejb3.Ejb3Deployment.deployUrl(Ejb3Deployment.java:692) [:1.
7.17]
at org.jboss.ejb3.Ejb3Deployment.deploy(Ejb3Deployment.java:655) [:1.7.1
7]
at org.jboss.ejb3.Ejb3Deployment.create(Ejb3Deployment.java:544) [:1.7.1
7]
at org.jboss.ejb3.deployers.Ejb3Deployer.deploy(Ejb3Deployer.java:177) [
:6.0.0.Final]
... 49 more
Caused by: java.lang.ClassNotFoundException: de.rapidanalytics.entity.Repository
Exception from BaseClassLoader@7f95327{vfs:///C:/RapidAnalytics/1.1/server/defau
lt/deploy/RapidAnalytics-CE-1.1.014.zip}
at org.jboss.classloader.spi.base.BaseClassLoader.loadClass(BaseClassLoa
der.java:480) [jboss-classloader.jar:2.2.0.GA]
at java.lang.ClassLoader.loadClass(Unknown Source) [:1.7.0_01]
... 77 more
21:46:31,906 INFO [service] Removing bootstrap log handlers
21:46:31,962 ERROR [ProfileServiceBootstrap] Failed to load profile:: org.jboss.
deployers.client.spi.IncompleteDeploymentException: Summary of incomplete deploy
ments (SEE PREVIOUS ERRORS FOR DETAILS):
DEPLOYMENTS IN ERROR:
Deployment "vfs:///C:/RapidAnalytics/1.1/server/default/deploy/RapidAnalytics-
CE-1.1.014.zip" is in error due to the following reason(s): java.lang.ClassNotFo
undException: de.rapidanalytics.entity.RepositoryException from BaseClassLoader@
7f95327{vfs:///C:/RapidAnalytics/1.1/server/default/deploy/RapidAnalytics-CE-1.1
.014.zip}
at org.jboss.deployers.plugins.deployers.DeployersImpl.checkComplete(Dep
loyersImpl.java:1228) [:2.2.0.GA]
at org.jboss.deployers.plugins.main.MainDeployerImpl.checkComplete(MainD
eployerImpl.java:905) [:2.2.0.GA]
at org.jboss.system.server.profileservice.deployers.MainDeployerPlugin.c
heckComplete(MainDeployerPlugin.java:87) [:6.0.0.Final]
at org.jboss.profileservice.deployment.ProfileDeployerPluginRegistry.che
ckAllComplete(ProfileDeployerPluginRegistry.java:107) [:0.2.2]
ootstrap.start(BasicProfileServiceBootstrap.java:135) [:6.0.0.Final]
21:46:32,004 INFO [org.apache.coyote.http11.Http11Protocol] Starting Coyote HTT
P/1.1 on http-127.0.0.1-8080
21:46:32,024 INFO [org.apache.coyote.ajp.AjpProtocol] Starting Coyote AJP/1.3 o
n ajp-127.0.0.1-8009
21:46:32,025 INFO [org.jboss.bootstrap.impl.base.server.AbstractServer] JBossAS
[6.0.0.Final "Neo"] Started in 1m:9s:320ms
