<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.014"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.014" expanded="true" name="Process"> <process expanded="true" height="477" width="706"> <operator activated="true" class="generate_nominal_data" compatibility="5.1.014" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"/> <operator activated="true" class="remember" compatibility="5.1.014" expanded="true" height="60" name="Remember" width="90" x="179" y="30"> <parameter key="name" value="original_data"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="subprocess" compatibility="5.1.014" expanded="true" height="76" name="Generate Fake File Data" width="90" x="45" y="120"> <process expanded="true" height="477" width="706"> <operator activated="true" class="generate_data_user_specification" compatibility="5.1.014" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="112" y="30"> <list key="attribute_values"> <parameter key="selected_attributes" value=""att1,att2,att5""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.1.014" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="112" y="120"> <list key="attribute_values"> <parameter key="selected_attributes" value=""att2,att4""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.1.014" expanded="true" height="94" name="Append" width="90" x="315" y="30"/> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Append" from_port="merged set" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="replace" compatibility="5.1.014" expanded="true" height="76" name="Replace" width="90" x="179" y="120"> <parameter key="replace_what" value=","/> <parameter key="replace_by" value="\|"/> </operator> <operator activated="true" class="loop_examples" compatibility="5.1.014" expanded="true" height="94" name="Loop Examples" width="90" x="313" y="120"> <process expanded="true" height="477" width="706"> <operator activated="true" class="extract_macro" compatibility="5.1.014" expanded="true" height="60" name="Extract Macro" width="90" x="45" y="30"> <parameter key="macro" value="selection_regex"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="selected_attributes"/> <parameter key="example_index" value="%{example}"/> </operator> <operator activated="true" class="recall" compatibility="5.1.014" expanded="true" height="60" name="Recall" width="90" x="45" y="120"> <parameter key="name" value="original_data"/> <parameter key="io_object" value="ExampleSet"/> <parameter key="remove_from_store" value="false"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.014" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="120"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="%{selection_regex}"/> </operator> <connect from_port="example set" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_port="example set"/> <connect from_op="Recall" from_port="result" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="output 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Remember" to_port="store"/> <connect from_op="Generate Fake File Data" from_port="out 1" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
