Hi all,
to classifiy texts, I use "Process Documents" to create TF_IDF vectors. These are used to learn a kNN. When I apply the KNN model to new data, I receive thousands of warnings like
Dec 7, 2011 6:37:15 PM com.rapidminer.tools.WrapperLoggingHandler logWarning WARNING: KNNClassification: The given example set does not contain a regular attribute with name 'XXX'. This might cause problems for some models depending on this particular attribute. |
where "XXX" stands for any word used within my texts.
Is there something wrong with my model?
Create Model:
<process version="5.1.014">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.014" expanded="true" name="Process">
<process expanded="true" height="579" width="708">
<operator activated="false" class="retrieve" compatibility="5.1.014" expanded="true" height="60" name="Retrieve" width="90" x="112" y="255">
<parameter key="repository_entry" value="data/v1_class_blogs"/>
<operator activated="false" class="optimize_parameters_grid" compatibility="5.1.014" expanded="true" height="94" name="Optimize Parameters (Grid)" width="90" x="581" y="30">
<list key="parameters">
<parameter key="k-NN.k" value="[1.0;3.0;10;linear]"/>
</list>
<process expanded="true" height="579" width="951">
<operator activated="false" class="x_validation" compatibility="5.1.014" expanded="true" height="112" name="Validation" width="90" x="246" y="30">
<parameter key="number_of_validations" value="3"/>
<process expanded="true">
<operator activated="false" class="naive_bayes" compatibility="5.1.014" expanded="true" name="Naive Bayes"/>
<operator activated="false" class="k_nn" compatibility="5.1.014" expanded="true" name="k-NN">
<parameter key="k" value="3"/>
<connect from_port="training" to_op="k-NN" to_port="training set"/>
<connect from_op="k-NN" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="false" class="apply_model" compatibility="5.1.014" expanded="true" name="Apply Model">
<operator activated="false" class="performance_classification" compatibility="5.1.014" expanded="true" name="Performance">
<list key="class_weights"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="false" class="log" compatibility="5.1.014" expanded="true" height="76" name="Log" width="90" x="434" y="66">
<list key="log">
<parameter key="k" value="operator.k-NN.parameter.k"/>
<parameter key="performance" value="operator.Performance.value.accuracy"/>
</list>
<connect from_port="input 1" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/>
<connect from_op="Log" from_port="through 1" to_port="performance"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
<operator activated="true" class="text:process_document_from_data" compatibility="5.1.003" expanded="true" height="76" name="Process Documents from Data" width="90" x="246" y="75">
<parameter key="prune_method" value="absolute"/>
<parameter key="prune_below_absolute" value="2"/>
<parameter key="prune_above_absolute" value="999"/>
<list key="specify_weights"/>
<process expanded="true" height="581" width="955">
<operator activated="true" class="text:transform_cases" compatibility="5.1.003" expanded="true" height="60" name="Transform Cases" width="90" x="112" y="30"/>
<operator activated="true" class="text:tokenize" compatibility="5.1.003" expanded="true" height="60" name="Tokenize" width="90" x="246" y="30"/>
<operator activated="true" class="text:filter_stopwords_german" compatibility="5.1.003" expanded="true" height="60" name="Filter Stopwords (German)" width="90" x="380" y="30"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.1.003" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="514" y="30"/>
<operator activated="true" class="text:stem_snowball" compatibility="5.1.003" expanded="true" height="60" name="Stem (Snowball)" width="90" x="648" y="30">
<parameter key="language" value="German"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.1.003" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="782" y="30">
<parameter key="max_chars" value="999"/>
<connect from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (German)" to_port="document"/>
<connect from_op="Filter Stopwords (German)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Stem (Snowball)" to_port="document"/>
<connect from_op="Stem (Snowball)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/>
</process>
<operator activated="false" class="x_validation" compatibility="5.1.014" expanded="true" height="112" name="Validation (2)" width="90" x="380" y="75">
<process expanded="true" height="597" width="459">
<operator activated="false" class="naive_bayes" compatibility="5.1.014" expanded="true" height="76" name="Naive Bayes (2)" width="90" x="179" y="120"/>
<operator activated="false" class="k_nn" compatibility="5.1.014" expanded="true" height="76" name="k-NN (2)" width="90" x="179" y="30">
<parameter key="k" value="2"/>
<connect from_port="training" to_op="k-NN (2)" to_port="training set"/>
<connect from_op="k-NN (2)" from_port="model" to_port="model"/>
</process>
<operator activated="false" class="apply_model" compatibility="5.1.014" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30">
<operator activated="false" class="performance_classification" compatibility="5.1.014" expanded="true" height="76" name="Performance (2)" width="90" x="246" y="165">
<connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
<connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/>
</process>
<operator activated="true" class="k_nn" compatibility="5.1.014" expanded="true" height="76" name="k-NN (3)" width="90" x="581" y="165">
<operator activated="false" class="text:process_document_from_data" compatibility="5.1.003" expanded="true" height="76" name="Process Documents from Data (2)" width="90" x="313" y="210">
<operator activated="false" class="text:transform_cases" compatibility="5.1.003" expanded="true" name="Transform Cases (2)"/>
<operator activated="false" class="text:tokenize" compatibility="5.1.003" expanded="true" name="Tokenize (2)"/>
<operator activated="false" class="text:filter_stopwords_german" compatibility="5.1.003" expanded="true" name="Filter Stopwords (2)"/>
<operator activated="false" class="text:filter_stopwords_english" compatibility="5.1.003" expanded="true" name="Filter Stopwords (3)"/>
<operator activated="false" class="text:stem_snowball" compatibility="5.1.003" expanded="true" name="Stem (2)">
<operator activated="false" class="text:filter_by_length" compatibility="5.1.003" expanded="true" name="Filter Tokens (2)">
<connect from_port="document" to_op="Transform Cases (2)" to_port="document"/>
<connect from_op="Transform Cases (2)" from_port="document" to_op="Tokenize (2)" to_port="document"/>
<connect from_op="Tokenize (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/>
<connect from_op="Filter Stopwords (2)" from_port="document" to_op="Filter Stopwords (3)" to_port="document"/>
<connect from_op="Filter Stopwords (3)" from_port="document" to_op="Stem (2)" to_port="document"/>
<connect from_op="Stem (2)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/>
<connect from_op="Filter Tokens (2)" from_port="document" to_port="document 1"/>
</process>
<operator activated="false" class="apply_model" compatibility="5.1.014" expanded="true" height="76" name="Apply Model (3)" width="90" x="552" y="312">
<connect from_port="input 1" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_op="k-NN (3)" to_port="training set"/>
<connect from_op="k-NN (3)" from_port="model" to_port="result 1"/>
</process>
</process>
Apply Model:
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="text:process_document_from_data" compatibility="5.1.003" expanded="true" height="76" name="Process Documents from Data" width="90" x="179" y="165">
</process>
<operator activated="true" class="read_model" compatibility="5.1.014" expanded="true" height="60" name="Read Model" width="90" x="179" y="75">
<parameter key="model_file" value="/MOUNT/BTRFS/CRAWLER/1und1/model.mod"/>
<operator activated="true" class="apply_model" compatibility="5.1.014" expanded="true" height="76" name="Apply Model" width="90" x="447" y="120">
<connect from_op="Process Documents from Data" from_port="example set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Read Model" from_port="output" to_op="Apply Model" to_port="model"/>
<connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/>
</process>
</process>
Regards
Merlot
