<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.011"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process"> <process expanded="true" height="621" width="932"> <operator activated="true" class="generate_data_user_specification" compatibility="5.1.011" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="30"> <list key="attribute_values"> <parameter key="TestAttribute" value=""a1,b1,c1,d1,a2,b2,c2,d2,a3,b3,c3,d3,a4,b4,c4,d4""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="split" compatibility="5.1.011" expanded="true" height="76" name="Split" width="90" x="179" y="30"/> <operator activated="true" class="transpose" compatibility="5.1.011" expanded="true" height="76" name="Transpose" width="90" x="313" y="30"/> <operator activated="true" class="generate_id" compatibility="5.1.011" expanded="true" height="76" name="Generate ID" width="90" x="447" y="30"> <parameter key="offset" value="-1"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.1.011" expanded="true" height="76" name="Generate Attributes" width="90" x="581" y="30"> <list key="function_descriptions"> <parameter key="index" value="mod(id,4)"/> <parameter key="id" value="floor(id / 4)"/> </list> </operator> <operator activated="true" class="pivot" compatibility="5.1.011" expanded="true" height="76" name="Pivot" width="90" x="715" y="30"> <parameter key="group_attribute" value="id"/> <parameter key="index_attribute" value="index"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Pivot" to_port="example set input"/> <connect from_op="Pivot" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
