Hello
I'm getting the same error.
server.log shows:
Caused by: java.sql.SQLException: ORA-12899: value too large for column "RAPIDM7"."es_46939_meta"."attributeName" (actual: 16, maximum: 8)
RM Studio error message is:
Cannot save repository data
Cannot store data in repository at entry '//Raptor.98/home/zzzzz'
Reason: Cannot upload object. 500 internal Server Error
We are using RM Studio 7.2 64bit and RM Server 7.2 64bit Linux
Oracle version is 11.2.0.1
Oracle Language Parameters are: (as in sys.pros$ table)
(1)NCHAR Character set - NLS_NCHAR_CHARACTERSET=UTF8
(2)Character set - NLS_CHARACTERSET=UTF8
(3)Language - NLS_LANGUAGE=KOREAN_KOREA.UTF8
Operators used in RM Studio:
(1) Read Excel
(2) Store (to server repository)
My personal analysis:
This error occurs when Korean Letters are in the excel header row (first row).
Korean letters in following rows (after the first row) have no problem.
Only the korean letters in the first row generates errors.
The excel table is supposed to be saved in tables such as "es_47542_meta", "es_47542_nominal_mapping", "es_47542_data_1".
The table "es_47542_meta" has column which name is attributeName.
This attributeName column does not work. It should contain the header letters
and when there is any Korean character in this header row,
necessary calculation to measure the length of this arributeName columen does not work.
We are using UTF-8, so every korean character needs 3 bytes.
If I insert a dummy (fictitous) header in any of the first header row which is large enough to hold the longest korean header,
then this process works fine.
For example, if the longest korean header has three korean letters, then
it requires nine bytes to hold it (3X3), then if there is any english header larger than 9 characters,
it generates the rapidminer table column attributeName as large as nine bytes and this process works fine.
It seems like the system (either RM or oracle) does not count the column width of Korean characters
represented in UTF-8 character set.
I used ojdbc7-12.1.0.jar for the jdbc driver of the RM server.
If I change it to ojdbc6.jar, it shows the same error.
This problem is not resolved yet.
Followings are what I tried to fix this, but it did not work. It shows the same error message.
1. standalone.conf
JAVA_OPTS="$JAVA_OPTS -Dfile.encoding=UTF-8" JAVA_OPTS="$JAVA_OPTS -DNLS_LANG=KOREAN_KOREA.UTF8" JAVA_OPTS="$JAVA_OPTS -Dsun.jnu.encoding=utf-8" JAVA_OPTS="$JAVA_OPTS -Djavax.servlet.request.encoding=UTF8" JAVA_OPTS="$JAVA_OPTS -Dorg.apache.catalina.connector.URI_ENCODING=UTF-8"
2. standalone.xml
<system-properties> <property name="org.apache.catalina.connector.URI_ENCODING" value="UTF-8"/> <property name="file.encoding" value="UTF-8"/> <property name="org.apache.catalina.connector.USE_BODY_ENCODING_FOR_QUERY_STRING" value="true"/> <property name="sun.jnu.encoding" value="UTF-8"/></system-properties>
<datasource jta="true" jndi-name="java:/jdbc/RapidAnalyticsDS" . . . . . . . . . . . . . .
<connection-property name="char.encoding">UTF-8</connection-property> <connection-property name="useUnicode">yes</connection-property> <connection-property name="connectionCollation">utf8_bin</connection-property> <connection-property name="characterSetResults">UTF-8</connection-property>
3. server.log shows following (entries related to UTF-8 character encoding)
NLS_LANG = KOREAN_KOREA.UTF8
[Standalone] =
java.version = 1.8.0_101
java.vm.name = Java HotSpot(TM) 64-Bit Server VM
os.name = Linux
os.version = 2.6.32-504.el6.x86_64
file.encoding = UTF-8
sun.io.unicode.encoding = UnicodeLittle
sun.jnu.encoding = UTF-8
user.language = ko
javax.servlet.request.encoding = UTF-8
org.apache.catalina.connector.URI_ENCODING = UTF-8
user.timezone = ROK
Anybody who can help us. Please.
Server.log shows following Errors:
1. case one
14:05:17,936 INFO [de.rapidanalytics.ejb.RepositoryStorageEJBImpl] (http-/0.0.0.0:8080-1) admin submitted new object to /hangul1/kortest1.14:05:18,061 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-1) Dropping data tables for es_12314:05:18,468 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-1) Failed to drop table: java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist. (Ignoring)14:05:18,499 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-1) Failed to drop table: java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist. (Ignoring)14:05:18,733 WARNING [de.rapidanalytics.entity.IOObjectVersion] (http-/0.0.0.0:8080-1) Cannot store example set: java.sql.SQLException: ORA-12899: value too large for column "RAPID"."es_123_meta"."attributeName" (actual: 6, maximum: 5): java.sql.SQLException: ORA-12899: value too large for column "RAPID"."es_123_meta"."attributeName" (actual: 6, maximum: 5)
2. case two:
13:09:57,120 INFO [de.rapidanalytics.ejb.RepositoryStorageEJBImpl] (http-/0.0.0.0:8080-2) admin submitted new object to /hangul1/kortest101.13:09:57,143 INFO [de.rapidanalytics.ejb.RepositoryEJBImpl] (http-/0.0.0.0:8080-2) admin created entry '/hangul1/kortest101 of type 'data'.13:09:57,194 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-2) Dropping data tables for es_64313:09:57,228 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-2) Cannot determine number of subtables. Probably tables already deleted: java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist
13:09:57,254 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-2) Failed to drop table: java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist . (Ignoring)13:09:57,257 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-2) Failed to drop table: java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist . (Ignoring)13:09:57,260 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-2) Failed to drop table: java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist . (Ignoring)13:09:57,385 WARNING [de.rapidanalytics.entity.IOObjectVersion] (http-/0.0.0.0:8080-2) Cannot store example set: java.sql.SQLException: ORA-12899: value too large for column "RAPM"."es_643_meta"."attributeName" (actual: 6, maximum: 5): java.sql.SQLException: ORA-12899: value too large for column "RAPM"."es_643_meta"."attributeName" (actual: 6, maximum: 5)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:450) [ojdbc7-12.1.0.2.jar:12.1.0.2.0] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:399) [ojdbc7-12.1.0.2.jar:12.1.0.2.0] at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:1017) [ojdbc7-12.1.0.2.jar:12.1.0.2.0] at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:655) [ojdbc7-12.1.0.2.jar:12.1.0.2.0]
Last time I used Rapidminer Server 7.2 on Linux using Operation Data in Oracle 12.1.0.2.0 with Character set UTF8.
I did the same test using a Rapidminer Server 7.2 on Windows 2012 with Oracle 12.1.0 with database created with Character set AL32UTF8.
It shows the same error.
This time I did some network TCP sniff to trace the actual data sent from studio to server.
It shows POST was used and Korean letters were encoded in UTF-8.
<< HTTP Packet sent from studio to Server >>
POST /api/rest/resources/hangul1/kortest1 HTTP/1.1Accept-Charset: UTF-8Content-Type: application/vnd.rapidminer.iooUser-Agent: Java/1.8.0_51Host: 192.168.80.202:8080Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2Connection: keep-aliveAuthorization: Basic YWRtaW46Y2hhbmdlaXQ=Content-Length: 569
*q.................aaabb........polynominal....single_value......................... ........
The last part include korean letters encoded in UTF-8 korean letters composed of 3 bytes.
<< Binary data Analysis >>
00000180 75 65 00 00 00 05 00 00 00 00 00 00 00 06 EC 82 ue...... ........ 00000190 AC EA B3 BC 00 00 00 01 00 00 00 09 ED 96 84 EB ........ ........ 000001A0 B2 84 EA B1 B0 00 00 00 02 00 00 00 0C ED 8C 8C ........ ........ 000001B0 EC 9D B8 EC 95 A0 ED 94 8C 00 00 00 03 00 00 00 ........ ........ 000001C0 0F EC 98 A4 EC A7 95 EC 96 B4 EC A7 AC EB BD 95 ........ ........
EC 82 AC (3bytes) is equivalent to Korean letter '사'
EA B3 BC (3bytes) is equivalent to Korean letter '과'
ED 96 84 (3bytes) is equivalent to Korean letter '햄'
EB B2 84 (3bytes) is equivalent to Korean letter '버'
Since you state the problem is in the header (first row) only, could it be related to your database (the one you use for the server) also? Most do not like 'strange characters' for column names, so what if you use more 'friendly' row headers? I had something similar in the past, where my row header was using 'illegal' characters according to my SQL database, but where it was perfectly OK to store them in the actual cells. I had to use a more friendly header and it was solved at that moment.
