Hey Guys,
I am working on a small project, and basically want to categorize text using a Naive Bayes classifier.
What I have done - created a process that trains the bayes classifier (using processed data) and serializes the classifier using write Model.
Furthermore, I have also stored the word list that was generated by the process documents from data (by using Wordlist to Data and storing it as an ARFF).
The process I am working on, and which I'm having problems with is the model applier to the data. I have a file which has a single line of text (the document to be categorized). I feed it into process documents, and have to also feed the aforementioned word list. So I load the word list by read ArFF and connect it to the wordlist input port on the process documents. However an error is thrown saying 'Expected WordList but received ExampleSet'.
How do i generate a WordList from the data? Or is the way I am storing it incorrect.
Thanks for any help! I really appreciate it!
The following is my XML:
<process version="5.1.011">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process">
<process expanded="true" height="679" width="1079">
<operator activated="true" class="read_model" compatibility="5.1.011" expanded="true" height="60" name="Read Classifier" width="90" x="447" y="30">
<parameter key="model_file" value="/Users/Funky/Desktop/Imperial/Third Year/Group Project/adcat/training/bayes_classifier_adcat"/>
<operator activated="true" class="read_csv" compatibility="5.1.011" expanded="true" height="60" name="Read Data" width="90" x="179" y="255">
<parameter key="csv_file" value="/Users/Funky/Desktop/Imperial/Third Year/Group Project/adcat/training/bayes_input.csv"/>
<parameter key="column_separators" value=","/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations"/>
<parameter key="encoding" value="MacRoman"/>
<parameter key="0" value="document.true.text.attribute"/>
</list>
<operator activated="true" class="read_arff" compatibility="5.1.011" expanded="true" height="60" name="Read ARFF" width="90" x="179" y="120">
<parameter key="data_file" value="/Users/Funky/Desktop/Imperial/Third Year/Group Project/adcat/training/process_documents_word_list.arff"/>
<list key="data_set_meta_data_information"/>
<operator activated="true" class="text:process_document_from_data" compatibility="5.1.003" expanded="true" height="76" name="Process Documents from Data" width="90" x="380" y="165">
<parameter key="vector_creation" value="Term Frequency"/>
<list key="specify_weights"/>
<operator activated="true" class="text:transform_cases" compatibility="5.1.003" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="30"/>
<operator activated="true" class="text:tokenize" compatibility="5.1.003" expanded="true" height="60" name="Tokenize" width="90" x="246" y="30"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.1.003" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="380" y="30">
<parameter key="min_chars" value="2"/>
<parameter key="max_chars" value="80"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.1.003" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="514" y="30"/>
<operator activated="true" class="text:stem_snowball" compatibility="5.1.003" expanded="true" height="60" name="Stem (Snowball)" width="90" x="648" y="30"/>
<operator activated="true" class="text:generate_n_grams_terms" compatibility="5.1.003" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="782" y="30">
<parameter key="max_length" value="4"/>
<connect from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Stem (Snowball)" to_port="document"/>
<connect from_op="Stem (Snowball)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/>
<connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.1.011" expanded="true" height="76" name="Apply Model" width="90" x="715" y="75">
<connect from_op="Read Classifier" from_port="output" to_op="Apply Model" to_port="model"/>
<connect from_op="Read Data" from_port="output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Read ARFF" from_port="output" to_op="Process Documents from Data" to_port="word list"/>
<connect from_op="Process Documents from Data" from_port="example set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/>
</process>
</process>
