<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.014"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.014" expanded="true" name="Process"> <process expanded="true" height="449" width="710"> <operator activated="true" class="web:get_webpage" compatibility="5.1.004" expanded="true" height="60" name="Get Page" width="90" x="45" y="75"> <parameter key="url" value="http://www.talktalkmembers.com/forums/forumdisplay.php?f=9&order=desc&page=13"/> <list key="query_parameters"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.1.003" expanded="true" height="94" name="Process Documents" width="90" x="179" y="75"> <parameter key="create_word_vector" value="false"/> <process expanded="true" height="449" width="710"> <operator activated="true" class="text:extract_information" compatibility="5.1.003" expanded="true" height="60" name="Extract Information" width="90" x="112" y="30"> <parameter key="query_type" value="XPath"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"> <parameter key="Test" value="//h:h1/text()"/> </list> <list key="namespaces"/> <list key="index_queries"/> </operator> <connect from_port="document" to_op="Extract Information" to_port="document"/> <connect from_op="Extract Information" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Get Page" from_port="output" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
