I'd like to filter examples based on a logical condition, for example that attribute B is bigger than attribute A. I cannot do this with FilterExamples. Is there another operator that I am missing? Follows an example code.
<process version="5.1.009">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.009" expanded="true" name="Process">
<process expanded="true" height="351" width="874">
<operator activated="true" class="generate_data_user_specification" compatibility="5.1.009" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="30">
<list key="attribute_values">
<parameter key="a" value="1"/>
<parameter key="b" value="2"/>
</list>
<operator activated="true" class="filter_examples" compatibility="5.1.009" expanded="true" height="76" name="Filter Examples" width="90" x="179" y="30">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="b > a"/>
<connect from_op="Generate Data by User Specification" from_port="output" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/>
Best regards,
Vinicius
