Hey,
in my process:
<process version="5.1.006">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Process">
<process expanded="true" height="444" width="563">
<operator activated="true" class="free_memory" compatibility="5.1.006" expanded="true" height="76" name="Free Memory" width="90" x="246" y="30"/>
<operator activated="true" class="loop_parameters" compatibility="5.1.006" expanded="true" height="76" name="Loop Parameters" width="90" x="380" y="30">
<list key="parameters">
<parameter key="Neural Net.learning_rate" value="0.3"/>
</list>
<operator activated="true" class="split_data" compatibility="5.1.006" expanded="true" height="94" name="Split Outer" width="90" x="45" y="30">
<enumeration key="partitions">
<parameter key="ratio" value="0.8"/>
<parameter key="ratio" value="0.2"/>
</enumeration>
<operator activated="true" class="x_validation" compatibility="5.1.006" expanded="true" height="112" name="Validation" width="90" x="180" y="30">
<parameter key="sampling_type" value="shuffled sampling"/>
<process expanded="true" height="444" width="165">
<operator activated="true" class="neural_net" compatibility="5.1.006" expanded="true" height="76" name="Neural Net" width="90" x="45" y="30">
<list key="hidden_layers"/>
<connect from_port="training" to_op="Neural Net" to_port="training set"/>
<connect from_op="Neural Net" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<process expanded="true" height="444" width="300">
<operator activated="true" class="apply_model" compatibility="5.1.006" expanded="true" height="76" name="CVApply" width="90" x="45" y="30">
<operator activated="true" class="performance_regression" compatibility="5.1.006" expanded="true" height="76" name="CVPerf" width="90" x="180" y="30">
<parameter key="absolute_error" value="true"/>
<parameter key="relative_error" value="true"/>
<parameter key="correlation" value="true"/>
<connect from_port="model" to_op="CVApply" to_port="model"/>
<connect from_port="test set" to_op="CVApply" to_port="unlabelled data"/>
<connect from_op="CVApply" from_port="labelled data" to_op="CVPerf" to_port="labelled data"/>
<connect from_op="CVPerf" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.1.006" expanded="true" height="76" name="HOApply" width="90" x="315" y="30">
<operator activated="true" class="performance_regression" compatibility="5.1.006" expanded="true" height="76" name="HOPerf" width="90" x="450" y="30">
<operator activated="true" class="log" compatibility="5.1.006" expanded="true" height="76" name="Log" width="90" x="447" y="210">
<list key="log">
<parameter key="CVPerformance" value="operator.CVPerf.value.performance"/>
<parameter key="HOPerformance" value="operator.HOPerf.value.performance"/>
<parameter key="CValidation" value="operator.Validation.value.performance"/>
</list>
<connect from_port="input 1" to_op="Split Outer" to_port="example set"/>
<connect from_op="Split Outer" from_port="partition 1" to_op="Validation" to_port="training"/>
<connect from_op="Split Outer" from_port="partition 2" to_op="HOApply" to_port="unlabelled data"/>
<connect from_op="Validation" from_port="model" to_op="HOApply" to_port="model"/>
<connect from_op="HOApply" from_port="labelled data" to_op="HOPerf" to_port="labelled data"/>
<connect from_op="HOApply" from_port="model" to_port="result 1"/>
<connect from_op="HOPerf" from_port="performance" to_op="Log" to_port="through 1"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
<connect from_op="Free Memory" from_port="through 1" to_op="Loop Parameters" to_port="input 1"/>
</process>
</process>
I am logging 3 different performance values. Whats the difference between logging the performance criterion from "CVPerf" and "CValidation"?
It has a tremendous effect on the logged value, which surprised me. I thought that the performance of the inner performance operator should be equal to the one outputted by the x-Validation Operator?
Thanks for the help!
