Unable to filter by cluster
I am trying to apply the clustering operator and then keep only the examples that belong to a specific cluster (using FilterExamples). But it does not work. I crafted a small example to reproduce the problem. It seems to be a bug, but I ask just in case I am doing something silly... Any help appreciated.
Vinicius
Best regards,
<process version="5.1.009">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.009" expanded="true" name="Process">
<process expanded="true" height="351" width="871">
<operator activated="true" class="generate_sales_data" compatibility="5.1.009" expanded="true" height="60" name="Generate Sales Data" width="90" x="45" y="30">
<parameter key="use_local_random_seed" value="true"/>
<operator activated="true" class="select_attributes" compatibility="5.1.009" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30">
<parameter key="attribute" value="single_price"/>
<operator activated="true" class="k_means" compatibility="5.1.009" expanded="true" height="76" name="Clustering" width="90" x="313" y="30"/>
<operator activated="true" class="filter_examples" compatibility="5.1.009" expanded="true" height="76" name="Filter Examples" width="90" x="447" y="30">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="cluster = "cluster_0""/>
<connect from_op="Generate Sales Data" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Clustering" to_port="example set"/>
<connect from_op="Clustering" from_port="clustered set" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/>
</process>
</process>
Vinicius
the reason is the filter parameter: just remove the " and empty spaces and it will work like a charm:
cluster=cluster_0
Here is the corrected process: Cheers,
Ingo
