<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.011"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process"> <process expanded="true" height="505" width="547"> <operator activated="true" class="generate_data" compatibility="5.1.011" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"> <parameter key="target_function" value="random classification"/> </operator> <operator activated="true" class="optimize_by_generation_yagga" compatibility="5.1.011" expanded="true" height="94" name="Generate" width="90" x="179" y="75"> <parameter key="reciprocal_value" value="false"/> <process expanded="true" height="527" width="725"> <operator activated="true" class="naive_bayes" compatibility="5.1.011" expanded="true" height="76" name="Naive Bayes" width="90" x="112" y="30"/> <operator activated="true" class="apply_model" compatibility="5.1.011" expanded="true" height="76" name="Apply Model" width="90" x="313" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.1.011" expanded="true" height="76" name="Performance" width="90" x="514" y="30"/> <connect from_port="example set source" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Naive Bayes" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="performance sink"/> <portSpacing port="source_example set source" spacing="0"/> <portSpacing port="sink_performance sink" spacing="0"/> </process> </operator> <operator activated="true" class="write_constructions" compatibility="5.1.011" expanded="true" height="60" name="Write Constructions" width="90" x="380" y="30"> <parameter key="attribute_constructions_file" value="C:\Users\mhelf\Documents\tmp\constructions"/> </operator> <operator activated="true" class="generate_data" compatibility="5.1.011" expanded="true" height="60" name="Generate Data (2)" width="90" x="45" y="255"> <parameter key="target_function" value="random classification"/> </operator> <operator activated="true" class="read_constructions" compatibility="5.1.011" expanded="true" height="60" name="Read Constructions" width="90" x="380" y="255"> <parameter key="attribute_constructions_file" value="C:\Users\mhelf\Documents\tmp\constructions"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate" to_port="example set in"/> <connect from_op="Generate" from_port="example set out" to_op="Write Constructions" to_port="input"/> <connect from_op="Generate" from_port="attribute weights out" to_port="result 2"/> <connect from_op="Write Constructions" from_port="through" to_port="result 1"/> <connect from_op="Generate Data (2)" from_port="output" to_op="Read Constructions" to_port="example set"/> <connect from_op="Read Constructions" from_port="example set" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
