<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.011"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process"> <process expanded="true" height="145" width="145"> <operator activated="true" class="text:create_document" compatibility="5.1.002" expanded="true" height="60" name="Create Document" width="90" x="45" y="30"> <parameter key="text" value="?????????????????"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.1.002" expanded="true" height="94" name="Process Documents" width="90" x="192" y="30"> <parameter key="vector_creation" value="Term Occurrences"/> <parameter key="add_meta_information" value="false"/> <parameter key="keep_text" value="true"/> <process expanded="true" height="449" width="658"> <operator activated="true" class="text:generate_n_grams_characters" compatibility="5.1.002" expanded="true" height="60" name="Generate n-Grams (Characters)" width="90" x="179" y="30"> <parameter key="length" value="1"/> </operator> <connect from_port="document" to_op="Generate n-Grams (Characters)" to_port="document"/> <connect from_op="Generate n-Grams (Characters)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Create Document" from_port="output" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_port="result 1"/> <connect from_op="Process Documents" from_port="word list" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
