"Information Extraction Plugin samples"
vbulcan99
I am trying to access the examples from "Information Extraction Plugin" without success
On Page 15 from the documentation you can see the Instructions :
The Information Extraction Plugin contains a folder storing a number of samples
which present the usage of the Information Extraction Plugin. To use
the samples just create a new Repository in RapidMiner referencing the folder
./<Information Extraction Plugin>/samples/. You can access the processes
stored in the samples-folder via the newly created Repository now.
but when I try to create new repository with Root directory: "./<Information Extraction Plugin>/samples/" the system is saying:
Oct 6, 2011 12:36:14 PM WARNING: Failed to create repository directory: com.rapidminer.repository.RepositoryException: Cannot create repository folder at '.\<Information Extraction Plugin>\samples'.
Oct 6, 2011 12:36:14 PM CONFIG: Adding repository NewLocalRepository
Oct 6, 2011 12:36:14 PM WARNING: Error storing repository entry properties to .\<Information Extraction Plugin>\samples\NewLocalRepository.properties: java.io.FileNotFoundException: .\<Information Extraction Plugin>\samples\NewLocalRepository.properties (The filename, directory name, or volume label syntax is incorrect)
Could you help me to solve this problem please
Thanks
Sampling
jcurry1
Hi
I just had the same issue. You need to download the samples seperately. They are not in the plug jar. You can get them at
https://ieplugin4rm.svn.sourceforge.net/svnroot/ieplugin4rm/informationextractionplugin_Vega/trunk/informationExtraction_Vega/samples/
I just downloaded them individually into a folder called samples and then created a repository to point towards that. (It is important to name them as given: ".rmp" or ".properties" as oppposed to just ".xml".) You can probably check out the whole folder in sourceforge but I am not familiar with sourceforge so I just did it this simple way.
They work ok now. There is a problem with the visualiser node in there though I think that is entirely a seperate issue. So I raised another post on this:
http://rapid-i.com/rapidforum/index.php/topic,6042.0.html
John.
yakito
Was anyone able to use this plugin to extract entities from a given text? I am totally lost with it, if someone can hint me on an example process that will extract entities from text I will deeply appreciate it.
Also, regarding the visualizer I am also experiencing the same issue, was anyone able to find a workaround?
Thanks in advance
