I'm now running a frequency response analysis (modal) for a model with about 6 million elements. The working station is equipped with 48 cores and about 512GB RAM.
AMSES is being used and since an analysis up to 2000Hz is required, the value of V2 for EIGRA cards (upper bound for frequency, at which the modes (eigenvalues) will be found) up to 3000Hz is desirable.
Because of the memory shortage, simulations with value of V2 only up to 2000Hz could be done. (with run option -len(46cores,500GB), -optskip). Are there any tricks, which can help reduce the amount of memory required for the simulation?
I'm looking forward to your reply! Thanks.
SIM
