MyExperiment is not working
Flake
I used to use it, and it worked well.
However, today, I tried to download workflow from MyExperiment, it does not work: after I select a search result, if I click "Open", it quickly shows a window which says "Pending task: download workflow", then it disappears within 1 second. Then, nothing happens afterward. So I cannot open anything from MyExperiment.
BTW, I remembered I did an extension update few days ago, but not sure if this extension was updated then.
Let me know if it is just me or it is a new issue?
Flake
And also, I want to use them via downloading from MyExperiment site. But the file downloaded is without type. I don't know how to use it. I tried opening with Notepad++ or rename to .xml, all I got are irrecognizable characters.
Any help would be appreciated.
Marco_Boeck
could you start RapidMiner via the command console, so you can see errors which may pop up? See
here
I just tried the Community extension, and it worked fine for me.
Marco
rizsa
I've got a same problem;
I used to use the myExperiment plugin and everything worked well til I had updated the rapidminer.
Now the plugin is exist, I can select and open a rapidminer process, but nothing loading into
the process window.
So, where is the problem, and what is the solution.
I've unistalled and installed the Rapidminer (deleted every sub-folder, and related files), but
the problem is still exist.
Istvan
