🎉Community Raffle - Win $25
Join and Win
XPath multiple record extraction
vbulcan99User: "vbulcan99"
New Altair Community Member
Updated by Jocelyn
Hello everyone,
I am trying to use "Extract Information" operator with XPath query type in order to duplicate
the video example: "Web Scraping with RapidMiner and XPath" from: http://vancouverdata.blogspot.com/2011/04/web-scraping-rapidminer-xpath-web.html
The techniq is working well if I am trying to extract one record with one or more atributes per page.
But if I try to extract an example all job links (http://vancouver.en.craigslist.ca/jjj/)
using the query: //h:blockquote/h:p[not(@align='center')]/h:a/@href
as was described on the tutorial (and is working on google spreadsheets)
"Extract Information" is returning just one random record instead of multiple records of all available job links from the page
I tryed to extend little bit the example by using "Crawl Web" operator in order to get the job links from more than one page
process them thru using macro aproach with 'Loop Examples' operator and finally to agregate the results in one final record set by using "Append" operator
but the system is failing for unexplained reasons.
here is the XML code:
<process version="5.1.011">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process">
    <process expanded="true" height="548" width="883">
      <operator activated="true" class="web:crawl_web" compatibility="5.1.004" expanded="true" height="60" name="Crawl Web (2)" width="90" x="45" y="165">
        <parameter key="url" value="http://vancouver.en.craigslist.ca/jjj/"/>
        <list key="crawling_rules">
          <parameter key="follow_link_with_matching_url" value=".*index.*"/>
          <parameter key="store_with_matching_url" value=".*index.*"/>
        </list>
        <parameter key="write_pages_into_files" value="false"/>
        <parameter key="add_pages_as_attribute" value="true"/>
        <parameter key="output_dir" value="C:\Users\Administrator\Documents\traRM"/>
        <parameter key="max_pages" value="3"/>
        <parameter key="max_depth" value="3"/>
        <parameter key="obey_robot_exclusion" value="false"/>
        <parameter key="really_ignore_exclusion" value="true"/>
      <operator activated="true" class="generate_id" compatibility="5.1.011" expanded="true" height="76" name="Generate ID" width="90" x="246" y="165"/>
      <operator activated="true" class="loop_examples" compatibility="5.1.011" expanded="true" height="94" name="Loop Examples (2)" width="90" x="447" y="165">
        <parameter key="iteration_macro" value="id"/>
        <process expanded="true" height="548" width="901">
          <operator activated="true" class="extract_macro" compatibility="5.1.011" expanded="true" height="60" name="Extract Macro (3)" width="90" x="246" y="30">
            <parameter key="macro" value="website_url"/>
            <parameter key="macro_type" value="data_value"/>
            <parameter key="attribute_name" value="Link"/>
            <parameter key="example_index" value="%{id}"/>
          <operator activated="true" class="web:get_webpage" compatibility="5.1.004" expanded="true" height="60" name="Get Page" width="90" x="112" y="210">
            <parameter key="url" value="%{website_url}"/>
            <list key="query_parameters"/>
          <operator activated="true" class="text:process_documents" compatibility="5.1.002" expanded="true" height="94" name="Process Documents (2)" width="90" x="313" y="165">
            <parameter key="create_word_vector" value="false"/>
            <parameter key="add_meta_information" value="false"/>
            <parameter key="keep_text" value="true"/>
              <operator activated="true" class="text:extract_information" compatibility="5.1.002" expanded="true" height="60" name="Extract Information (4)" width="90" x="380" y="30">
                <parameter key="query_type" value="XPath"/>
                <list key="string_machting_queries"/>
                <list key="regular_expression_queries"/>
                <list key="regular_region_queries"/>
                <list key="xpath_queries">
                  <parameter key="xpath" value="//h:blockquote/h:p[not(@align='center')]/h:a/@href"/&gt;
                </list>
                <list key="namespaces"/>
                <list key="index_queries"/>
              <connect from_port="document" to_op="Extract Information (4)" to_port="document"/>
              <connect from_op="Extract Information (4)" from_port="document" to_port="document 1"/>
            </process>
          <connect from_port="example set" to_op="Extract Macro (3)" to_port="example set"/>
          <connect from_op="Extract Macro (3)" from_port="example set" to_port="example set"/>
          <connect from_op="Get Page" from_port="output" to_op="Process Documents (2)" to_port="documents 1"/>
          <connect from_op="Process Documents (2)" from_port="example set" to_port="output 1"/>
          <portSpacing port="sink_example set" spacing="0"/>
          <portSpacing port="sink_output 1" spacing="0"/>
          <portSpacing port="sink_output 2" spacing="0"/>
        </process>
      <operator activated="true" breakpoints="before" class="append" compatibility="5.1.011" expanded="true" height="76" name="Append (2)" width="90" x="648" y="165"/>
      <connect from_op="Crawl Web (2)" from_port="Example Set" to_op="Generate ID" to_port="example set input"/>
      <connect from_op="Generate ID" from_port="example set output" to_op="Loop Examples (2)" to_port="example set"/>
      <connect from_op="Loop Examples (2)" from_port="output 1" to_op="Append (2)" to_port="example set 1"/>
      <connect from_op="Append (2)" from_port="merged set" to_port="result 1"/>
    </process>
</process>
Could you help me to solve this problem please
Thanks
1 - 2 of 21
    LokyUser: "Loky"
    I'm working on something similar too.
    You'll have to use Cut Document to be able to extract multiple similar stuff from one document. Do a search on this forum and you'll fine some example. I start building my process based on this and it works pretty good.
    Good luck.
    Hi Loky,
    Thank you very much for advise to use "Cut Document" it is working excellent for me.
    for anybody experiencing same problem here is solution:
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
        <process expanded="true" height="657" width="955">
          <operator activated="true" class="web:crawl_web" compatibility="5.1.004" expanded="true" height="60" name="Crawl Web (2)" width="90" x="45" y="30">
            </list>
            <parameter key="max_pages" value="2"/>
          <operator activated="true" class="generate_id" compatibility="5.1.011" expanded="true" height="76" name="Generate ID" width="90" x="179" y="30"/>
          <operator activated="true" class="loop_examples" compatibility="5.1.011" expanded="true" height="94" name="Loop Examples (2)" width="90" x="313" y="30">
              <operator activated="true" class="text:cut_document" compatibility="5.1.003" expanded="true" height="60" name="Cut Document (4)" width="90" x="313" y="210">
                </list>
                <list key="namespaces">
                  <parameter key="xx" value="xml"/>
                </list>
                <parameter key="ignore_CDATA" value="false"/>
                <process expanded="true" height="598" width="984">
                  <connect from_port="segment" to_port="document 1"/>
                  <portSpacing port="source_segment" spacing="0"/>
                </process>
              <operator activated="true" class="extract_macro" compatibility="5.1.011" expanded="true" height="60" name="Extract Macro (2)" width="90" x="447" y="30">
                <parameter key="macro" value="website_page"/>
                <parameter key="attribute_name" value="Page"/>
              <connect from_op="Extract Macro (3)" from_port="example set" to_op="Extract Macro (2)" to_port="example set"/>
              <connect from_op="Get Page" from_port="output" to_op="Cut Document (4)" to_port="document"/>
              <connect from_op="Cut Document (4)" from_port="documents" to_port="output 1"/>
              <connect from_op="Extract Macro (2)" from_port="example set" to_port="example set"/>
            </process>
          <operator activated="true" class="text:process_documents" compatibility="5.1.003" expanded="true" height="94" name="Process Documents" width="90" x="447" y="30">
            <process expanded="true" height="580" width="966">
              <connect from_port="document" to_port="document 1"/>
            </process>
          <operator activated="true" class="generate_id" compatibility="5.1.011" expanded="true" height="76" name="Generate ID (2)" width="90" x="581" y="30"/>
          <operator activated="true" class="append" compatibility="5.1.011" expanded="true" height="76" name="Append (2)" width="90" x="715" y="30"/>
          <operator activated="true" class="write_excel" compatibility="5.1.011" expanded="true" height="60" name="Write Excel" width="90" x="849" y="30">
            <parameter key="excel_file" value="D:\Desktop\links.xls"/>
          <connect from_op="Loop Examples (2)" from_port="output 1" to_op="Process Documents" to_port="documents 1"/>
          <connect from_op="Process Documents" from_port="example set" to_op="Generate ID (2)" to_port="example set input"/>
          <connect from_op="Generate ID (2)" from_port="example set output" to_op="Append (2)" to_port="example set 1"/>
          <connect from_op="Append (2)" from_port="merged set" to_op="Write Excel" to_port="input"/>
          <connect from_op="Write Excel" from_port="through" to_port="result 1"/>
        </process>
    </process>
