<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.011"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process"> <process expanded="true" height="206" width="413"> <operator activated="true" class="generate_data" compatibility="5.1.011" expanded="true" height="60" name="Generate Data" width="90" x="112" y="75"> <parameter key="target_function" value="three ring clusters"/> <parameter key="number_of_attributes" value="2"/> </operator> <operator activated="true" class="aggregate" compatibility="5.1.011" expanded="true" height="76" name="Aggregate" width="90" x="313" y="75"> <list key="aggregation_attributes"> <parameter key="label" value="count"/> </list> <parameter key="group_by_attributes" value="|label"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
