<process version="5.1.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.009" expanded="true" name="Root"> <process expanded="true" height="584" width="962"> <operator activated="true" class="retrieve" compatibility="5.1.009" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="../../data/Polynomial"/> </operator> <operator activated="true" class="optimize_parameters_grid" compatibility="5.1.009" expanded="true" height="94" name="ParameterOptimization" width="90" x="246" y="30"> <list key="parameters"> <parameter key="Training.C" value="50,100,150,200,250"/> <parameter key="Training.degree" value="1,2,3,4,5"/> </list> <process expanded="true" height="626" width="806"> <operator activated="true" class="x_validation" compatibility="5.1.009" expanded="true" height="112" name="Validation" width="90" x="45" y="30"> <parameter key="sampling_type" value="shuffled sampling"/> <process expanded="true" height="272" width="334"> <operator activated="true" class="support_vector_machine_libsvm" compatibility="5.1.009" expanded="true" height="76" name="Training" width="90" x="126" y="30"> <parameter key="svm_type" value="epsilon-SVR"/> <parameter key="kernel_type" value="poly"/> <parameter key="degree" value="5"/> <parameter key="C" value="250"/> <parameter key="epsilon" value="0.01"/> <list key="class_weights"/> </operator> <connect from_port="training" to_op="Training" to_port="training set"/> <connect from_op="Training" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="272" width="334"> <operator activated="true" class="apply_model" compatibility="5.1.009" expanded="true" height="76" name="Test" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_regression" compatibility="5.1.009" expanded="true" height="76" name="Evaluation" width="90" x="194" y="30"> <parameter key="absolute_error" value="true"/> <parameter key="normalized_absolute_error" value="true"/> <parameter key="squared_error" value="true"/> </operator> <connect from_port="model" to_op="Test" to_port="model"/> <connect from_port="test set" to_op="Test" to_port="unlabelled data"/> <connect from_op="Test" from_port="labelled data" to_op="Evaluation" to_port="labelled data"/> <connect from_op="Evaluation" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.1.009" expanded="true" height="76" name="Log" width="90" x="246" y="75"> <parameter key="filename" value="paraopt.log"/> <list key="log"> <parameter key="C" value="operator.Training.parameter.C"/> <parameter key="degree" value="operator.Training.parameter.degree"/> <parameter key="absolute" value="operator.Validation.value.performance"/> </list> <parameter key="persistent" value="true"/> </operator> <connect from_port="input 1" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="ParameterOptimization" to_port="input 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
<process version="5.1.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.009" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="parallelize_main_process" value="false"/> <process expanded="true" height="694" width="740"> <operator activated="true" class="read_csv" compatibility="5.1.009" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30"> <parameter key="csv_file" value="H:\PRIVATE\Personal\Lisp\NCAA\Predictor12\Data\all-data-train.csv"/> <parameter key="column_separators" value=",\s*|;\s*"/> <parameter key="trim_lines" value="true"/> <parameter key="use_quotes" value="true"/> <parameter key="quotes_character" value="""/> <parameter key="escape_character_for_quotes" value="\"/> <parameter key="skip_comments" value="true"/> <parameter key="comment_characters" value="#"/> <parameter key="parse_numbers" value="true"/> <parameter key="decimal_character" value="."/> <parameter key="grouped_digits" value="false"/> <parameter key="grouping_character" value=","/> <parameter key="date_format" value="yyyy-MM-dd"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="Date.true.date.attribute"/> <parameter key="1" value="Line.true.binominal.attribute"/> <parameter key="2" value="Hname.true.polynominal.attribute"/> <parameter key="3" value="Hscore.true.real.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <parameter key="datamanagement" value="double_array"/> </operator> <operator activated="true" class="optimize_selection" compatibility="5.1.009" expanded="true" height="94" name="Optimize Selection" width="90" x="313" y="30"> <parameter key="selection_direction" value="forward"/> <parameter key="limit_generations_without_improval" value="true"/> <parameter key="generations_without_improval" value="2"/> <parameter key="limit_number_of_generations" value="false"/> <parameter key="keep_best" value="1"/> <parameter key="maximum_number_of_generations" value="20"/> <parameter key="normalize_weights" value="true"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="show_stop_dialog" value="true"/> <parameter key="user_result_individual_selection" value="false"/> <parameter key="show_population_plotter" value="false"/> <parameter key="plot_generations" value="10"/> <parameter key="constraint_draw_range" value="false"/> <parameter key="draw_dominated_points" value="true"/> <parameter key="maximal_fitness" value="Infinity"/> <parameter key="parallelize_evaluation_process" value="false"/> <process expanded="true" height="759" width="650"> <operator activated="true" class="linear_regression" compatibility="5.1.009" expanded="true" height="94" name="Linear Regression" width="90" x="112" y="30"> <parameter key="feature_selection" value="M5 prime"/> <parameter key="alpha" value="0.05"/> <parameter key="max_iterations" value="10"/> <parameter key="forward_alpha" value="0.05"/> <parameter key="backward_alpha" value="0.05"/> <parameter key="eliminate_colinear_features" value="true"/> <parameter key="min_tolerance" value="0.05"/> <parameter key="use_bias" value="true"/> <parameter key="ridge" value="1.0E-8"/> </operator> <operator activated="true" class="apply_model" compatibility="5.1.009" expanded="true" height="76" name="Apply Model (3)" width="90" x="246" y="30"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="performance_regression" compatibility="5.1.009" expanded="true" height="76" name="Performance (3)" width="90" x="380" y="30"> <parameter key="main_criterion" value="first"/> <parameter key="root_mean_squared_error" value="true"/> <parameter key="absolute_error" value="false"/> <parameter key="relative_error" value="false"/> <parameter key="relative_error_lenient" value="false"/> <parameter key="relative_error_strict" value="false"/> <parameter key="normalized_absolute_error" value="false"/> <parameter key="root_relative_squared_error" value="false"/> <parameter key="squared_error" value="false"/> <parameter key="correlation" value="false"/> <parameter key="squared_correlation" value="false"/> <parameter key="prediction_average" value="false"/> <parameter key="spearman_rho" value="false"/> <parameter key="kendall_tau" value="false"/> <parameter key="skip_undefined_labels" value="true"/> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="example set" to_op="Linear Regression" to_port="training set"/> <connect from_op="Linear Regression" from_port="model" to_op="Apply Model (3)" to_port="model"/> <connect from_op="Linear Regression" from_port="exampleSet" to_op="Apply Model (3)" to_port="unlabelled data"/> <connect from_op="Apply Model (3)" from_port="labelled data" to_op="Performance (3)" to_port="labelled data"/> <connect from_op="Performance (3)" from_port="performance" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <connect from_op="Read CSV" from_port="output" to_op="Optimize Selection" to_port="example set in"/> <connect from_op="Optimize Selection" from_port="example set out" to_port="result 2"/> <connect from_op="Optimize Selection" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
