<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.011"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process"> <process expanded="true" height="386" width="748"> <operator activated="true" class="generate_data" compatibility="5.1.011" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="generate_id" compatibility="5.1.011" expanded="true" height="76" name="Generate ID" width="90" x="45" y="120"/> <operator activated="true" class="set_role" compatibility="5.1.011" expanded="true" height="76" name="Set Role" width="90" x="45" y="210"> <parameter key="name" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.011" expanded="true" height="76" name="Select Attributes" width="90" x="45" y="300"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|id"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.1.011" expanded="true" height="60" name="Extract Macro" width="90" x="179" y="30"> <parameter key="macro" value="mean"/> <parameter key="macro_type" value="statistics"/> <parameter key="attribute_name" value="id"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.1.011" expanded="true" height="76" name="Generate Attributes" width="90" x="179" y="120"> <list key="function_descriptions"> <parameter key="difference" value="id-%{mean}"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
