I'm trying to authorize altair Hyperworks using a license code with almutil but every time i put the authorization token in the box and click authorize there is an error: 'Unable to authorize with Hosted HWU system'.
Can anyone help me?
Thank you
I'm having the same error. Did anyone find a resolution to this problem?
It is preferable, for you to log into Altair One, on your app (HyperWorks in your case). Here is a KB article you can use for reference:
https://community.altair.com/community?id=kb_article&sys_id=a0025eb9db9bb410cfd5f6a4e2961952
Similar problem with FEKO. The answer above did not help, since it is impossible to enter License Setup.
Hello, I follow the article:
but there is always the license error when I open hypermesh.
I attach screen of error.
Domenico, looks like you are using a on-prem server license (not hosted license), and the that license expires in 29 days. You need to work with your admin to make sure there is a new license file in place before the current one expires.
If you are intending to use hosted licenses, pls use the first option that says Hosted on Altair One, and enter your Altair One user name and password to activate your account.
