for (Attribute attribute : exampleSet.getAttributes()) { double value = example.getValue(attribute); if (nominal) { if (!Double.isNaN(value)) { int intValue = (int) value; for (int i = 0; i < numberOfClasses; i++) { if (intValue < distributionProperties.length) { probabilities += distributionProperties[intValue]; } } } else { for (int i = 0; i < numberOfClasses; i++) { probabilities += distributionProperties[distributionProperties.length - 1]; } } } else { if (!Double.isNaN(value)) { for (int i = 0; i < numberOfClasses; i++) { double base = (value - distributionProperties[INDEX_MEAN]) / distributionProperties[INDEX_STANDARD_DEVIATION]; probabilities -= distributionProperties[INDEX_LOG_FACTOR] + 0.5 * base * base; } } } j++; }
