Hi Rapid term:
I try install RapidAnalytics(RapidAnalytics-1.0.000-JBoss-bundle) in my computer(Windows 7 x64 4G Java:1.6.0_22,Database: Oracle 10g ),I oracle-ds.xml(url、password) file and copy ojdbc.jar to server/server/default/lib/,but excuted run.bat,report error :
Error installing to Start: name=persistence.unit:unitName=RapidAnalytics.ear/lib/RapidRepositoryEntity.jar#RapidRepositoryEntity state=Create: javax.naming.NameNotFoundException: jdbc not bound
15:34:24,005 INFO [JBossASKernel] with dependencies:
15:34:24,005 INFO [JBossASKernel] and demands:
15:34:24,005 INFO [JBossASKernel] jboss.ejb:service=EJBTimerService; Required: Described
15:34:24,005 INFO [JBossASKernel] persistence.unit:unitName=RapidAnalytics.ear/lib/RapidRepositoryEntity.jar#RapidRepositoryEntity; Required: Described
15:34:24,005 INFO [JBossASKernel] jndi:RapidAnalytics/RepositoryEJBImpl/local-de.rapidanalytics.ejb.RepositoryEJB; Required: Described
15:34:24,005 INFO [JBossASKernel] and supplies:
15:34:24,005 INFO [JBossASKernel] jndi:RapidAnalytics/TriggerManagementEJBImpl/local-de.rapidanalytics.ejb.TriggerManagementEJB
15:34:24,005 INFO [JBossASKernel] Class:de.rapidanalytics.ejb.TriggerManagementEJB
15:34:24,005 INFO [JBossASKernel] jndi:TriggerManagementEJBImpl
15:34:24,005 INFO [JBossASKernel] Added bean(jboss.j2ee:ear=RapidAnalytics.ear,jar=RapidRepositoryEJB.jar,name=TriggerManagementEJBImpl,service=EJB3) to KernelDeployment of: RapidRepositoryEJB.jar
15:34:24,504 INFO [PersistenceUnitDeployment] Starting persistence unit persistence.unit:unitName=RapidAnalytics.ear/lib/RapidRepositoryEntity.jar#RapidRepositoryEntity
15:34:24,566 ERROR [AbstractKernelController] Error installing to Start: name=persistence.unit:unitName=RapidAnalytics.ear/lib/RapidRepositoryEntity.jar#RapidRepositoryEntity state=Create: javax.naming.NameNotFoundException: jdbc not bound
at org.jnp.server.NamingServer.getBinding(NamingServer.java:771)
at org.jnp.server.NamingServer.getBinding(NamingServer.java:779)
at org.jnp.server.NamingServer.getObject(NamingServer.java:785)
at org.jnp.server.NamingServer.lookup(NamingServer.java:396)
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:728)
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:688)
at javax.naming.InitialContext.lookup(InitialContext.java:392)
at org.jboss.jpa.impl.deployment.PersistenceUnitInfoImpl.<init>(PersistenceUnitInfoImpl.java:120)
at org.jboss.jpa.deployment.PersistenceUnitDeployment.start(PersistenceUnitDeployment.java:293)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.jboss.reflect.plugins.introspection.ReflectionUtils.invoke(ReflectionUtils.java:59)
at org.jboss.reflect.plugins.introspection.ReflectMethodInfoImpl.invoke(ReflectMethodInfoImpl.java:151)
at org.jboss.joinpoint.plugins.BasicMethodJoinPoint.dispatch(BasicMethodJoinPoint.java:66)
at org.jboss.kernel.plugins.dependency.KernelControllerContextAction$JoinpointDispatchWrapper.execute(KernelControllerContextAction.java:257)
at org.jboss.kernel.plugins.dependency.ExecutionWrapper.execute(ExecutionWrapper.java:47)
at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchExecutionWrapper(KernelControllerContextAction.java:125)
at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchJoinPoint(KernelControllerContextAction.java:72)
at org.jboss.kernel.plugins.dependency.LifecycleAction.installActionInternal(LifecycleAction.java:202)
at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:54)
at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:42)
at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62)
at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71)
at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51)
at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:378)
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:2029)
at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:1050)
at org.jboss.dependency.plugins.AbstractController.executeOrIncrementStateDirectly(AbstractController.java:1289)
at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1213)
at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1107)
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:873)
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:620)
at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:180)
at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:58)
at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62)
at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:55)
at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:179)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1660)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1378)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1399)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1431)
at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1319)
at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:918)
at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:633)
at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:898)
at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:677)
at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117)
at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70)
at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53)
at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:403)
at org.jboss.system.server.profileservice.repository.AbstractProfileService.registerProfile(AbstractProfileService.java:308)
at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:259)
at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:100)
at org.jboss.bootstrap.impl.base.server.AbstractServer.startBootstraps(AbstractServer.java:860)
at org.jboss.bootstrap.impl.base.server.AbstractServer$StartServerTask.run(AbstractServer.java:441)
at java.lang.Thread.run(Thread.java:662)
15:34:25,846 警告 [Injector] duplicate class definition bug occured? Please report this : de/rapidanalytics/web/service/ProcessResponse$JaxbAccessorM_getOutputLocations_setOutputLocations_[Ljava_lang_String;: java.lang.ClassFormatError: Illegal class name "de/rapidanalytics/web/service/ProcessResponse$JaxbAccessorM_getOutputLocations_setOutputLocations_[Ljava_lang_String;" in class file de/rapidanalytics/web/service/ProcessResponse$JaxbAccessorM_getOutputLocations_setOutputLocations_[Ljava_lang_String;
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:632)
at java.lang.ClassLoader.defineClass(ClassLoader.java:616)
at java.lang.ClassLoader.defineClass(ClassLoader.java:466)
at sun.reflect.GeneratedMethodAccessor123.invoke(Unknown Source)
at com.sun.xml.bind.v2.runtime.reflect.opt.Injector.inject(Injector.java:205)
at com.sun.xml.bind.v2.runtime.reflect.opt.Injector.inject(Injector.java:85)
at com.sun.xml.bind.v2.runtime.reflect.opt.AccessorInjector.prepare(AccessorInjector.java:89)
at com.sun.xml.bind.v2.runtime.reflect.opt.OptimizedAccessorFactory.get(OptimizedAccessorFactory.java:114)
at com.sun.xml.bind.v2.runtime.reflect.Accessor$GetterSetterReflection.optimize(Accessor.java:369)
at com.sun.xml.bind.v2.runtime.property.ArrayProperty.<init>(ArrayProperty.java:65)
at com.sun.xml.bind.v2.runtime.property.ArrayERProperty.<init>(ArrayERProperty.java:84)
at com.sun.xml.bind.v2.runtime.property.ArrayElementProperty.<init>(ArrayElementProperty.java:96)
at com.sun.xml.bind.v2.runtime.property.ArrayElementLeafProperty.<init>(ArrayElementLeafProperty.java:66)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at com.sun.xml.bind.v2.runtime.property.PropertyFactory.create(PropertyFactory.java:124)
at com.sun.xml.bind.v2.runtime.ClassBeanInfoImpl.<init>(ClassBeanInfoImpl.java:179)
at com.sun.xml.bind.v2.runtime.JAXBContextImpl.getOrCreate(JAXBContextImpl.java:515)
at com.sun.xml.bind.v2.runtime.JAXBContextImpl.getOrCreate(JAXBContextImpl.java:534)
at com.sun.xml.bind.v2.runtime.property.SingleElementNodeProperty.<init>(SingleElementNodeProperty.java:101)
at sun.reflect.GeneratedConstructorAccessor45.newInstance(Unknown Source)
at com.sun.xml.bind.v2.runtime.JAXBContextImpl.<init>(JAXBContextImpl.java:330)
at com.sun.xml.bind.v2.runtime.JAXBContextImpl$JAXBContextBuilder.build(JAXBContextImpl.java:1140)
at com.sun.xml.bind.v2.ContextFactory.createContext(ContextFactory.java:154)
at com.sun.xml.bind.api.JAXBRIContext.newInstance(JAXBRIContext.java:106)
at org.jboss.ws.core.jaxws.CustomizableJAXBContextFactory.createContext(CustomizableJAXBContextFactory.java:123)
at org.jboss.ws.metadata.builder.jaxws.JAXWSMetaDataBuilder.createJAXBContext(JAXWSMetaDataBuilder.java:1002)
at org.jboss.ws.metadata.builder.jaxws.JAXWSWebServiceMetaDataBuilder.buildWebServiceMetaData(JAXWSWebServiceMetaDataBuilder.java:162)
at org.jboss.ws.metadata.builder.jaxws.JAXWSServerMetaDataBuilder.setupProviderOrWebService(JAXWSServerMetaDataBuilder.java:50)
at org.jboss.ws.metadata.builder.jaxws.JAXWSMetaDataBuilderJSE.buildMetaData(JAXWSMetaDataBuilderJSE.java:62)
at org.jboss.wsf.stack.jbws.UnifiedMetaDataDeploymentAspect.start(UnifiedMetaDataDeploymentAspect.java:64)
at org.jboss.webservices.integration.deployers.WSDeploymentAspectDeployer.internalDeploy(WSDeploymentAspectDeployer.java:107)
Please help!Thank you !
