problems starting IDA Wizard extesnsion
amnonkhen
New Altair Community Member
Hi all,
Has anyone been able to successfully set up the IDA Wizard extension (http://www.e-lico.eu/?q=idawizard)?
I followed the instructions mentioned:
It looks like flora is running OK (I ran runflora.bat).
I see the IDA Tools menu items, and when I select the "Start IDA Wizard" option from the menu I get an error message.
The error dialog I get says:
[tt]Error starting planner: null[/tt]
The java exception I see is:
[tt]
Exception: ch.uzh.ifi.ddis.ida.api.exception.IDAException
Message: null
Stack trace:
ch.uzh.ifi.ddis.ida.core.IDAManager.getMainGoals(IDAManager.java:718)
ch.uzh.ifi.ddis.ida.core.IDAInterfaceImpl.getMainGoals(IDAInterfaceImpl.java:83)
com.rapidminer.elico.ida.IDAController.getMainGoals(IDAController.java:130)
com.rapidminer.elico.ida.gui.wizard.IDAWizard$1.run(IDAWizard.java:76)
com.rapidminer.gui.tools.ProgressThread$2.run(ProgressThread.java:176)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.lang.Thread.run(Unknown Source)
[/tt]
Software I am using:
Does anyone have an idea what the problem is or how to solve it?
I wish Rapid Miner's error message were more informative.
Thanks for your help,
Amnon Khen
- http://www.e-lico.eu/?q=idawizard
- http://www.eimgco.eu/?q=node/199 - I could not patch the string.P file
- http://flora.sourceforge.net/download.php
- http://flora.sourceforge.net/installation.html
[tt]
Message: null
Stack trace:
[/tt]
- Rapid Miner 5.1.011 (It also happened on an earlier 5.0 version)
- Windows XP 32bit
- XSB 3.2
- Flora 0.95 (Androcymbium)
- my computer is in an environment that does not have access to the web
Amnon Khen
