<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.011"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process"> <process expanded="true" height="607" width="758"> <operator activated="true" class="text:create_document" compatibility="5.1.001" expanded="true" height="60" name="Create Document" width="90" x="45" y="30"> <parameter key="text" value="marker Document 1 content marker marker Document 2 content marker marker Document 3 content marker marker Document 4 content marker marker Document 5 content marker"/> </operator> <operator activated="true" class="text:cut_document" compatibility="5.1.001" expanded="true" height="60" name="Cut Document" width="90" x="179" y="30"> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"> <parameter key="content" value="marker.marker"/> </list> <list key="regular_expression_queries"> <parameter key="content" value="marker\s*(.*?)\s*marker"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> <process expanded="true" height="607" width="758"> <connect from_port="segment" to_port="document 1"/> <portSpacing port="source_segment" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_collection" compatibility="5.1.011" expanded="true" height="76" name="Loop Collection" width="90" x="313" y="30"> <process expanded="true" height="607" width="758"> <operator activated="true" class="text:write_document" compatibility="5.1.001" expanded="true" height="60" name="Write Document" width="90" x="45" y="30"> <parameter key="file" value="C:\Dokumente und Einstellungen\mraeder\Desktop\output\document_%{a}.txt"/> </operator> <connect from_port="single" to_op="Write Document" to_port="document"/> <connect from_op="Write Document" from_port="document" to_port="output 1"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Create Document" from_port="output" to_op="Cut Document" to_port="document"/> <connect from_op="Cut Document" from_port="documents" to_op="Loop Collection" to_port="collection"/> <connect from_op="Loop Collection" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.011"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process"> <process expanded="true" height="607" width="758"> <operator activated="true" class="text:create_document" compatibility="5.1.001" expanded="true" height="60" name="Create Document" width="90" x="45" y="30"> <parameter key="text" value="marker Document 1 content marker marker Document 2 content marker marker Document 3 content marker marker Document 4 content marker marker Document 5 content marker"/> </operator> <operator activated="true" class="text:cut_document" compatibility="5.1.001" expanded="true" height="60" name="Cut Document" width="90" x="179" y="30"> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"> <parameter key="content" value="marker.marker"/> </list> <list key="regular_expression_queries"> <parameter key="content" value="marker\s*(.*?)\s*marker"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> <process expanded="true" height="607" width="758"> <connect from_port="segment" to_port="document 1"/> <portSpacing port="source_segment" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:documents_to_data" compatibility="5.1.001" expanded="true" height="76" name="Documents to Data" width="90" x="313" y="30"> <parameter key="text_attribute" value="content"/> <parameter key="add_meta_information" value="false"/> </operator> <operator activated="true" class="generate_id" compatibility="5.1.011" expanded="true" height="76" name="Generate ID" width="90" x="447" y="30"/> <operator activated="true" class="generate_attributes" compatibility="5.1.011" expanded="true" height="76" name="Generate Attributes" width="90" x="581" y="30"> <list key="function_descriptions"> <parameter key="document" value=""document_" + str(id)"/> </list> </operator> <operator activated="true" class="write_excel" compatibility="5.1.011" expanded="true" height="60" name="Write Excel" width="90" x="581" y="165"> <parameter key="excel_file" value="C:\Dokumente und Einstellungen\mraeder\Desktop\output\documents.xls"/> </operator> <connect from_op="Create Document" from_port="output" to_op="Cut Document" to_port="document"/> <connect from_op="Cut Document" from_port="documents" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Documents to Data" from_port="example set" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Write Excel" to_port="input"/> <connect from_op="Write Excel" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="126"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.011"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process"> <process expanded="true" height="673" width="1299"> <operator activated="true" class="read_excel" compatibility="5.1.011" expanded="true" height="60" name="Read Excel" width="90" x="149" y="177"> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="5.1.002" expanded="true" height="76" name="ProcessDocs Train" width="90" x="514" y="75"> <parameter key="keep_text" value="true"/> <list key="specify_weights"/> <process expanded="true" height="655" width="1275"> <operator activated="true" class="text:transform_cases" compatibility="5.1.002" expanded="true" height="60" name="Transform Cases" width="90" x="204" y="275"/> <operator activated="true" class="text:replace_tokens" compatibility="5.1.002" expanded="true" height="60" name="Replace Tokens" width="90" x="259" y="152"> <list key="replace_dictionary"> <parameter key="e-mail" value="email"/> <parameter key="i'm" value="i am"/> </list> </operator> <operator activated="true" class="text:tokenize" compatibility="5.1.002" expanded="true" height="60" name="Tokenize" width="90" x="315" y="30"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.1.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="450" y="30"/> <operator activated="true" class="text:stem_snowball" compatibility="5.1.002" expanded="true" height="60" name="Stem (Snowball)" width="90" x="585" y="30"/> <operator activated="true" class="text:filter_by_length" compatibility="5.1.002" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="720" y="30"> <parameter key="min_chars" value="2"/> <parameter key="max_chars" value="999"/> </operator> <connect from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Replace Tokens" to_port="document"/> <connect from_op="Replace Tokens" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Stem (Snowball)" to_port="document"/> <connect from_op="Stem (Snowball)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="k_means" compatibility="5.1.011" expanded="true" height="76" name="Clustering" width="90" x="849" y="75"> <parameter key="k" value="6"/> <parameter key="max_runs" value="12"/> </operator> <connect from_op="Read Excel" from_port="output" to_op="ProcessDocs Train" to_port="example set"/> <connect from_op="ProcessDocs Train" from_port="example set" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_port="result 2"/> <connect from_op="Clustering" from_port="clustered set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="162"/> </process> </operator></process>
