"A big problem instalation"
Hi, I've been installing R.analytics and in my laptop it works fine, and the server too but in the desktop PC, I have a problem, I don´t know why!! I've tried all ! I've read all the post, do all and nothing please help me! this is the error...
19:28:24,673 WARN [JBossManagedConnectionPool] Throwable while attempting to get a new connection: null: org.jboss.resource.JBossResourceException: Could not create connection; - nested throwable: (java.sql.SQLException: Network error IOException: Connection refused: connect)
at org.jboss.resource.adapter.jdbc.local.LocalManagedConnectionFactory.getLocalManagedConnection(LocalManagedConnectionFactory.java:225)
at org.jboss.resource.adapter.jdbc.local.LocalManagedConnectionFactory.createManagedConnection(LocalManagedConnectionFactory.java:195)
at org.jboss.resource.connectionmanager.InternalManagedConnectionPool.createConnectionEventListener(InternalManagedConnectionPool.java:643)
at org.jboss.resource.connectionmanager.InternalManagedConnectionPool.getConnection(InternalManagedConnectionPool.java:267)
at org.jboss.resource.connectionmanager.JBossManagedConnectionPool$BasePool.getConnection(JBossManagedConnectionPool.java:659)
at org.jboss.resource.connectionmanager.BaseConnectionManager2.getManagedConnection(BaseConnectionManager2.java:404)
at org.jboss.resource.connectionmanager.TxConnectionManager.getManagedConnection(TxConnectionManager.java:381)
at org.jboss.resource.connectionmanager.BaseConnectionManager2.allocateConnection(BaseConnectionManager2.java:497)
at org.jboss.resource.connectionmanager.BaseConnectionManager2$ConnectionManagerProxy.allocateConnection(BaseConnectionManager2.java:942)
at org.jboss.resource.adapter.jdbc.WrapperDataSource.getConnection(WrapperDataSource.java:89)
at org.hibernate.ejb.connection.InjectedDataSourceConnectionProvider.getConnection(InjectedDataSourceConnectionProvider.java:71)
at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:114)
at org.hibernate.cfg.Configuration.buildSettingsInternal(Configuration.java:2163)
at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2159)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1383)
at org.hibernate.cfg.AnnotationConfiguration.buildSessionFactory(AnnotationConfiguration.java:974)
at org.hibernate.ejb.Ejb3Configuration.buildEntityManagerFactory(Ejb3Configuration.java:850)
at org.hibernate.ejb.HibernatePersistence.createContainerEntityManagerFactory(HibernatePersistence.java:73)
at org.jboss.jpa.builder.DefaultCEMFBuilder.build(DefaultCEMFBuilder.java:47)
at org.jboss.jpa.deployment.PersistenceUnitDeployment.start(PersistenceUnitDeployment.java:316)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.jboss.reflect.plugins.introspection.ReflectionUtils.invoke(ReflectionUtils.java:59)
at org.jboss.reflect.plugins.introspection.ReflectMethodInfoImpl.invoke(ReflectMethodInfoImpl.java:151)
at org.jboss.joinpoint.plugins.BasicMethodJoinPoint.dispatch(BasicMethodJoinPoint.java:66)
at org.jboss.kernel.plugins.dependency.KernelControllerContextAction$JoinpointDispatchWrapper.execute(KernelControllerContextAction.java:257)
at org.jboss.kernel.plugins.dependency.ExecutionWrapper.execute(ExecutionWrapper.java:47)
at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchExecutionWrapper(KernelControllerContextAction.java:125)
at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchJoinPoint(KernelControllerContextAction.java:72)
at org.jboss.kernel.plugins.dependency.LifecycleAction.installActionInternal(LifecycleAction.java:202)
at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:54)
at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:42)
at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62)
at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71)
at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51)
at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:378)
Caused by: javax.resource.ResourceException: Unable to get managed connection for jdbc/RapidAnalyticsDS
at org.jboss.resource.connectionmanager.BaseConnectionManager2.getManagedConnection(BaseConnectionManager2.java:442)
... 73 more
Caused by: org.jboss.resource.JBossResourceException: Could not create connection; - nested throwable: (java.sql.SQLException: Network error IOException: Connection refused: connect)
... 77 more
Caused by: java.sql.SQLException: Network error IOException: Connection refused: connect
at net.sourceforge.jtds.jdbc.ConnectionJDBC2.<init>(ConnectionJDBC2.java:385)
at net.sourceforge.jtds.jdbc.ConnectionJDBC3.<init>(ConnectionJDBC3.java:50)
at net.sourceforge.jtds.jdbc.Driver.connect(Driver.java:182)
at org.jboss.resource.adapter.jdbc.local.LocalManagedConnectionFactory.getLocalManagedConnection(LocalManagedConnectionFactory.java:207)
... 82 more
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:525)
at net.sourceforge.jtds.jdbc.SharedSocket.createSocketForJDBC3(SharedSocket.java:304)
at net.sourceforge.jtds.jdbc.SharedSocket.<init>(SharedSocket.java:255)
at net.sourceforge.jtds.jdbc.ConnectionJDBC2.<init>(ConnectionJDBC2.java:310)
... 85 more
19:28:24,704 ERROR [AbstractKernelController] Error installing to Start: name=persistence.unit:unitName=RapidAnalytics.ear/lib/RapidRepositoryEntity.jar#RapidRepositoryEntity state=Create: javax.persistence.PersistenceException: [PersistenceUnit: RapidRepositoryEntity] Unable to build EntityManagerFactory
at org.hibernate.ejb.Ejb3Configuration.buildEntityManagerFactory(Ejb3Configuration.java:859)
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:2029)
at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:1050)
at org.jboss.dependency.plugins.AbstractController.executeOrIncrementStateDirectly(AbstractController.java:1289)
at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1213)
at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1107)
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:873)
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:620)
at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:180)
at org.jboss.deployers.vfs.deployer.kernel.BeanMetaDataDeployer.deploy(BeanMetaDataDeployer.java:58)
at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62)
at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:55)
at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:179)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1660)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1378)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1399)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1431)
at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1319)
at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:918)
at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:633)
at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:898)
at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:677)
at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117)
at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70)
at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53)
at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:403)
at org.jboss.system.server.profileservice.repository.AbstractProfileService.registerProfile(AbstractProfileService.java:308)
at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:259)
at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:100)
at org.jboss.bootstrap.impl.base.server.AbstractServer.startBootstraps(AbstractServer.java:860)
at org.jboss.bootstrap.impl.base.server.AbstractServer$StartServerTask.run(AbstractServer.java:441)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.hibernate.HibernateException: 'hibernate.dialect' must be set when no Connection available
at org.hibernate.dialect.resolver.DialectFactory.buildDialect(DialectFactory.java:107)
at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:138)
... 66 more
DEPLOYMENTS IN ERROR:
Deployment "vfszip:/C:/rapidanalytics/server/default/deploy/RapidAnalytics.ear/" is in error due to the following reason(s): org.jboss.deployers.spi.DeploymentException: URL file:/C:/rapidanalytics/server/default/tmp/3o6w101l-qdg4ut-gsduvpq2-1-gsduwpm9-9x/RapidRepositoryWeb.war/ deployment failed
19:28:34,922 INFO [org.apache.coyote.http11.Http11Protocol] Arrancando Coyote HTTP/1.1 en puerto http-0.0.0.0-8080
19:28:34,938 INFO [org.apache.coyote.ajp.AjpProtocol] Arrancando Coyote AJP/1.3 en ajp-0.0.0.0-8009
19:28:34,938 INFO [org.jboss.bootstrap.impl.base.server.AbstractServer] JBossAS [6.0.0.20100216-M2 (build: SVNTag=JBoss_6_0_0_20100216-M2 date=20100216)] Started in 58s:937ms
