🎉Community Raffle - Win $25
Join and Win
Operator "Subprocess" doesn't pass through data
User: "colo"
New Altair Community Member
Updated by Jocelyn
Hi (Marco),
I experienced a new issue, that should again be something to fix easily ;)
If the operator "Subprocess" contains no active operators, there are no results delivered at the output port of the operator, although input and output ports of the inner process are connected. Adding some dummy operator (I chose "Select Attributes" with all attributes) changes this. I guess this again should just require a small change/fix, but please let me know if I may expect a general fix from your side, or if I have to do this by myself for now.
Best regards
Matthias
