is it possible to compare ROCs of models with different subsets of attributes? I'm trying to compare the ROCs fo 2 Naive Bayes models, one has the full set of attributes and the other only has a subset. I tried including "Remove Correlated Attributes" / "Select Attributes" in the "Compare ROCs" process but I keep getting errors. "Select Attributes" displays the following error:
Exception: java.lang.ArrayIndexOutOfBoundsException
Message: 1
Stack trace:
com.rapidminer.operator.learner.bayes.SimpleDistributionModel.performPrediction(SimpleDistributionModel.java:447)
com.rapidminer.operator.learner.PredictionModel.apply(PredictionModel.java:76)
com.rapidminer.operator.visualization.ROCBasedComparisonOperator.doWork(ROCBasedComparisonOperator.java:173)
com.rapidminer.operator.Operator.execute(Operator.java:831)
com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51)
com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:709)
com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:369)
com.rapidminer.Process.run(Process.java:902)
com.rapidminer.Process.run(Process.java:798)
com.rapidminer.Process.run(Process.java:793)
com.rapidminer.Process.run(Process.java:783)
com.rapidminer.gui.ProcessThread.run(ProcessThread.java:63)
Anyone know what I'm doing wrong?
Your help would be greatly appreciated!
