colo wrote:since you can see the results in the results view, you have probably connected the data flow from the last operator to the results port of the process. If you just append the "Write Excel" operator to the end of the process, you can easily export the table (the things you see in the data view) into an excel file.
Sebastian Land wrote:this functionality is part of the enterprise version only. There you can export every table format into an excel sheet...
