<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <process expanded="true" height="206" width="212"> <operator activated="true" class="text:process_document_from_file" compatibility="5.1.002" expanded="true" height="76" name="Process Documents from Files" width="90" x="112" y="30"> <list key="text_directories"> <parameter key="class1" value="c:\temp\class1"/> <parameter key="class2" value="c:\temp\class2"/> </list> <parameter key="extract_text_only" value="false"/> <process expanded="true" height="809" width="852"> <operator activated="true" class="text:tokenize" compatibility="5.1.002" expanded="true" height="60" name="Tokenize" width="90" x="253" y="30"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Process Documents from Files" from_port="example set" to_port="result 1"/> <connect from_op="Process Documents from Files" from_port="word list" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
