Sub GetData() Dim QuerySheet As Worksheet Dim DataSheet As Worksheet Dim EndDate As Date Dim StartDate As Date Dim Symbol As String Dim qurl As String Application.ScreenUpdating = False Application.DisplayAlerts = False Application.Calculation = xlCalculationManual Set DataSheet = ActiveSheet StartDate = DataSheet.Range("B2").Value EndDate = DataSheet.Range("B3").Value Symbol = DataSheet.Range("B4").Value Range("C7").CurrentRegion.ClearContents 'construct the URL for the query qurl = "http://chart.yahoo.com/table.csv?s=" & Symbol qurl = qurl & "&a=" & Month(StartDate) - 1 & "&b=" & Day(StartDate) & _ "&c=" & Year(StartDate) & "&d=" & Month(EndDate) - 1 & "&e=" & _ Day(EndDate) & "&f=" & Year(EndDate) & "&g=" & Range("C3") & "&q=q&y=0&z=" & _ Symbol & "&x=.csv" Range("c5") = qurl QueryQuote: With ActiveSheet.QueryTables.Add(Connection:="URL;" & qurl, Destination:=DataSheet.Range("C7")) .BackgroundQuery = True .TablesOnlyFromHTML = False .Refresh BackgroundQuery:=False .SaveData = True End With Range("C7").CurrentRegion.TextToColumns Destination:=Range("C7"), DataType:=xlDelimited, _ TextQualifier:=xlDoubleQuote, ConsecutiveDelimiter:=False, Tab:=True, _ Semicolon:=False, Comma:=True, Space:=False, other:=False Range(Range("C7"), Range("C7").End(xlDown)).NumberFormat = "mmm d/yy" Range(Range("D7"), Range("G7").End(xlDown)).NumberFormat = "0.00" Range(Range("H7"), Range("H7").End(xlDown)).NumberFormat = "0,000"UpdateScaleRemoveNames'turn calculation back on Application.Calculation = xlCalculationAutomatic Application.DisplayAlerts = True Range("C7:H2000").Select Selection.Sort Key1:=Range("C8"), Order1:=xlAscending, Header:=xlGuess, _ OrderCustom:=1, MatchCase:=False, Orientation:=xlTopToBottom Range("B4").SelectPasteEnd Sub
