Dear group members,
I am new to RM. I am trying to integrate RM in to my java program and also I integrated it. I created a NetBeans project that has only one class containing the following code. I can successfully run the project from NetBeans but unfortunately when I run it from the jar (java -jar RapidMinerText.jar) , it gives "java.lang.NoClassDefFoundError" exception  >:(
I used the execution mode EMBEDDED_WITHOUT_UI.
The code:
package rapidminertext;
import java.util.logging.Level;
import java.util.logging.Logger;
public class RapidMinerText {
    public static void main(String[] args) {
        com.rapidminer.RapidMiner.setExecutionMode(com.rapidminer.RapidMiner.ExecutionMode.EMBEDDED_WITHOUT_UI);
        System.setProperty("rapidminer.home", "/rapidminer");
        System.setProperty(com.rapidminer.RapidMiner.PROPERTY_RAPIDMINER_INIT_PLUGINS_LOCATION, "/rapidminer/lib/plugins");
        com.rapidminer.RapidMiner.init();
        try {
            com.rapidminer.Process p = new com.rapidminer.Process();
            com.rapidminer.operator.Operator doc = com.rapidminer.tools.OperatorService.createOperator(
                    com.rapidminer.operator.text.io.SingleDocumentInputOperator.class);
            doc.setParameter("text", "this is a text.");
            System.out.println("\tcreated: " + doc.getOperatorDescription());
            p.getRootOperator().getSubprocess(0).addOperator(doc);
            doc.getOutputPorts().getPortByName("output").connectTo(
                    p.getRootOperator().getSubprocess(0).getInnerSinks().getPortByName("result 1"));
            System.out.println(p.getRootOperator().createProcessTree(0));
            com.rapidminer.operator.IOContainer run = p.run();
            System.out.println(run.toString());
        } catch (Exception ex) {
            Logger.getLogger(RapidMinerText.class.getName()).log(Level.SEVERE, null, ex);
The output of the program:
2011-08-10 11:30:56 CONFIG: Locale not specified explicitly. Set default locale to US. (RapidMiner.init())
2011-08-10 11:30:56 CONFIG: Initializing I18N (RapidMiner.splashMessage())
2011-08-10 11:30:56 CONFIG: Ensuring RapidMiner Home is set (RapidMiner.splashMessage())
2011-08-10 11:30:56 INFO: rapidminer.home is '/rapidminer'. (Launcher.ensureRapidMinerHomeSet())
2011-08-10 11:30:56 CONFIG: Reading Configuration Files (RapidMiner.splashMessage())
2011-08-10 11:30:56 CONFIG: Reading configuration resource com/rapidminer/resources/rapidminerrc. (ParameterService.loadAllRCFiles())
2011-08-10 11:30:56 CONFIG: Neither system property 'rapidminer.config.dir' nor environment variable 'RAPIDMINER_CONFIG_DIR' not set. Ignored. (ParameterService.getGlobalConfigDir())
2011-08-10 11:30:56 CONFIG: Trying rcfile '/Users/murtoza/.RapidMiner5/5_1_006_rapidminerrc'...skipped (ParameterService.loadRCFile())
2011-08-10 11:30:56 CONFIG: Read rcfile '/Users/murtoza/.RapidMiner5/5_1_006_rapidminerrc.Mac OS X'. (ParameterService.loadRCFile())
2011-08-10 11:30:56 CONFIG: Trying rcfile '/RapidMinerText/rapidminerrc'...skipped (ParameterService.loadRCFile())
2011-08-10 11:30:56 CONFIG: Trying rcfile '/RapidMinerText/rapidminerrc.Mac OS X'...skipped (ParameterService.loadRCFile())
2011-08-10 11:30:56 CONFIG: Property rapidminer.rcfile not specified...skipped (ParameterService.loadAllRCFiles())
2011-08-10 11:30:56 CONFIG: Registering Plugins (RapidMiner.splashMessage())
2011-08-10 11:30:56 CONFIG: Scanning plugins in /rapidminer/lib/plugins. (Plugin.findAndRegisterPlugins())
2011-08-10 11:30:57 CONFIG: Loading renderers from 'Text Processing'. (RendererService.init())
2011-08-10 11:30:57 CONFIG: Reading parse rules from jar:file:/rapidminer/lib/plugins/rapidminer-Text%20Processing-5.1.001.jar!/com/rapidminer/resources/parserulesTextProcessing.xml (XMLImporter.importParseRules())
2011-08-10 11:30:57 CONFIG: Initializing Operators (RapidMiner.splashMessage())
2011-08-10 11:30:57 CONFIG: Loading operators from 'OperatorsCore.xml'. (OperatorService.registerOperators())
2011-08-10 11:30:57 CONFIG: Loading operator documentation from jar:file:/RapidMinerText/dist/lib/rapidminer.jar!/com/rapidminer/resources/i18n/OperatorsCoreDocumentation.xml. (OperatorDocBundle$XMLControl.newBundle())
2011-08-10 11:30:59 WARNING: Password in XML file looks like unencrypted plain text. (ParameterTypePassword.decryptPassword())
2011-08-10 11:31:00 CONFIG: Loading operators from '/rapidminer/lib/plugins/rapidminer-Text Processing-5.1.001.jar'. (OperatorService.registerOperators())
2011-08-10 11:31:00 CONFIG: Loading operator documentation from jar:file:/rapidminer/lib/plugins/rapidminer-Text%20Processing-5.1.001.jar!/com/rapidminer/resources/i18n/OperatorsDocTextProcessing.xml. (OperatorDocBundle$XMLControl.newBundle())
2011-08-10 11:31:00 CONFIG: Number of registered operator classes: 461; number of registered operator descriptions: 462; number of replacements: 433 (OperatorService.init())
2011-08-10 11:31:00 CONFIG: Loading operator usage statistics. (UsageStatistics.load())
2011-08-10 11:31:00 CONFIG: Initializing XML Transformation Rules (RapidMiner.splashMessage())
2011-08-10 11:31:00 CONFIG: Reading parse rules from jar:file:/RapidMinerText/dist/lib/rapidminer.jar!/com/rapidminer/resources/parserules.xml (XMLImporter.importParseRules())
2011-08-10 11:31:00 CONFIG: Loading JDBC Drivers (RapidMiner.splashMessage())
2011-08-10 11:31:00 CONFIG: Loading JDBC driver information from 'resource jdbc_properties.xml'. (DatabaseService.loadJDBCProperties())
2011-08-10 11:31:00 INFO: JDBC driver com.mysql.jdbc.Driver not found. Probably the driver is not installed. (JDBCProperties.registerDrivers())
2011-08-10 11:31:00 INFO: JDBC driver org.postgresql.Driver not found. Probably the driver is not installed. (JDBCProperties.registerDrivers())
2011-08-10 11:31:00 INFO: JDBC driver net.sourceforge.jtds.jdbc.Driver not found. Probably the driver is not installed. (JDBCProperties.registerDrivers())
2011-08-10 11:31:00 INFO: JDBC driver org.hsqldb.jdbcDriver not found. Probably the driver is not installed. (JDBCProperties.registerDrivers())
2011-08-10 11:31:00 WARNING: Missing database driver class name for 'ODBC Bridge (e.g. Access)' (JDBCProperties.<init>())
2011-08-10 11:31:00 INFO: JDBC driver com.ingres.jdbc.IngresDriver not found. Probably the driver is not installed. (JDBCProperties.registerDrivers())
2011-08-10 11:31:00 INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed. (JDBCProperties.registerDrivers())
2011-08-10 11:31:00 INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found. Probably the driver is not installed. (JDBCProperties.registerDrivers())
2011-08-10 11:31:00 CONFIG: Neither system property 'rapidminer.config.dir' nor environment variable 'RAPIDMINER_CONFIG_DIR' not set. Ignored. (ParameterService.getGlobalConfigDir())
2011-08-10 11:31:00 CONFIG: Initializing Data Repository (RapidMiner.splashMessage())
2011-08-10 11:31:00 CONFIG: Loading repositories from /Users/murtoza/.RapidMiner5/repositories.xml (RepositoryManager.load())
2011-08-10 11:31:00 CONFIG: Adding repository IMServiceLocalRepository (RepositoryManager.addRepository())
2011-08-10 11:31:00 CONFIG: Initializing Renderers (RapidMiner.splashMessage())
2011-08-10 11:31:00 CONFIG: Loading renderers from 'file:/RapidMinerText/dist/lib/rapidminer.jar!/com/rapidminer/resources/ioobjects.xml'. (RendererService.init())
2011-08-10 11:31:00 CONFIG: Loading renderers from 'ioobjects.xml'. (RendererService.init())
2011-08-10 11:31:00 CONFIG: Initializing XML Serialization (RapidMiner.splashMessage())
Exception in thread "main" java.lang.NoClassDefFoundError: com/rapidminer/operator/text/io/SingleDocumentInputOperator
	at rapidminertext.RapidMinerText.main(RapidMinerText.java:18)
Caused by: java.lang.ClassNotFoundException: com.rapidminer.operator.text.io.SingleDocumentInputOperator
	at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
	... 1 more
Anyone please help me. How can I solve it.
Thanks
