<process version="5.1.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Process"> <process expanded="true" height="317" width="1686"> <operator activated="true" class="retrieve" compatibility="5.1.006" expanded="true" height="60" name="Retrieve" width="90" x="45" y="75"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="generate_id" compatibility="5.1.006" expanded="true" height="76" name="Generate ID" width="90" x="179" y="75"/> <operator activated="true" class="multiply" compatibility="5.1.006" expanded="true" height="94" name="Multiply" width="90" x="313" y="75"/> <operator activated="true" class="naive_bayes" compatibility="5.1.006" expanded="true" height="76" name="Naive Bayes" width="90" x="447" y="120"/> <operator activated="true" class="apply_model" compatibility="5.1.006" expanded="true" height="76" name="Apply Model (2)" width="90" x="581" y="120"> <list key="application_parameters"/> </operator> <operator activated="true" class="decision_tree" compatibility="5.1.006" expanded="true" height="76" name="Decision Tree" width="90" x="447" y="30"/> <operator activated="true" class="apply_model" compatibility="5.1.006" expanded="true" height="76" name="Apply Model" width="90" x="581" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.1.006" expanded="true" height="76" name="Yes Filter" width="90" x="715" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="prediction(Play)=yes"/> </operator> <operator activated="true" class="multiply" compatibility="5.1.006" expanded="true" height="94" name="Multiply (2)" width="90" x="849" y="30"/> <operator activated="true" class="set_minus" compatibility="5.1.006" expanded="true" height="76" name="No & default" width="90" x="983" y="120"/> <operator activated="true" class="append" compatibility="5.1.006" expanded="true" height="94" name="Merge" width="90" x="1117" y="30"/> <operator activated="true" class="sort" compatibility="5.1.006" expanded="true" height="76" name="Sort" width="90" x="1251" y="30"> <parameter key="attribute_name" value="id"/> </operator> <operator activated="true" class="performance_classification" compatibility="5.1.006" expanded="true" height="76" name="Performance" width="90" x="1385" y="30"> <list key="class_weights"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Decision Tree" to_port="training set"/> <connect from_op="Multiply" from_port="output 2" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Naive Bayes" from_port="exampleSet" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="No & default" to_port="example set input"/> <connect from_op="Decision Tree" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Decision Tree" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Yes Filter" to_port="example set input"/> <connect from_op="Yes Filter" from_port="example set output" to_op="Multiply (2)" to_port="input"/> <connect from_op="Multiply (2)" from_port="output 1" to_op="Merge" to_port="example set 1"/> <connect from_op="Multiply (2)" from_port="output 2" to_op="No & default" to_port="subtrahend"/> <connect from_op="No & default" from_port="example set output" to_op="Merge" to_port="example set 2"/> <connect from_op="Merge" from_port="merged set" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
