<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <process expanded="true" height="505" width="681"> <operator activated="true" class="subprocess" compatibility="5.1.008" expanded="true" height="76" name="Get news pages" width="90" x="45" y="30"> <process expanded="true" height="580" width="667"> <operator activated="true" class="web:get_webpage" compatibility="5.1.001" expanded="true" height="60" name="Get Page" width="90" x="45" y="30"> <parameter key="url" value="http://www.repubblica.it/"/> <parameter key="random_user_agent" value="true"/> <list key="query_parameters"/> </operator> <operator activated="true" class="text:cut_document" compatibility="5.1.002" expanded="true" height="60" name="Cut Document" width="90" x="179" y="30"> <parameter key="query_type" value="XPath"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"> <parameter key="article-link" value="//h:h3/h:a[contains(@href,'news')]/@href"/> </list> <list key="namespaces"/> <list key="index_queries"/> <process expanded="true"> <connect from_port="segment" to_port="document 1"/> <portSpacing port="source_segment" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:documents_to_data" compatibility="5.1.002" expanded="true" height="76" name="Documents to Data" width="90" x="313" y="30"> <parameter key="text_attribute" value="news-links"/> <parameter key="add_meta_information" value="false"/> </operator> <operator activated="true" class="web:retrieve_webpages" compatibility="5.1.001" expanded="true" height="60" name="Get Pages" width="90" x="447" y="30"> <parameter key="link_attribute" value="news-links"/> <parameter key="page_attribute" value="content"/> <parameter key="random_user_agent" value="true"/> </operator> <connect from_op="Get Page" from_port="output" to_op="Cut Document" to_port="document"/> <connect from_op="Cut Document" from_port="documents" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Documents to Data" from_port="example set" to_op="Get Pages" to_port="Example Set"/> <connect from_op="Get Pages" from_port="Example Set" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="subprocess" compatibility="5.1.008" expanded="true" height="76" name="Extract content" width="90" x="246" y="30"> <process expanded="true" height="598" width="570"> <operator activated="true" class="text:data_to_documents" compatibility="5.1.002" expanded="true" height="60" name="Data to Documents" width="90" x="45" y="30"> <parameter key="select_attributes_and_weights" value="true"/> <list key="specify_weights"> <parameter key="content" value="1.0"/> </list> </operator> <operator activated="true" class="loop_collection" compatibility="5.1.008" expanded="true" height="76" name="Loop Collection" width="90" x="180" y="30"> <process expanded="true"> <operator activated="true" class="web:extract_html_text_content" compatibility="5.1.001" expanded="true" name="Extract Content (2)"> <parameter key="minimum_text_block_length" value="10"/> </operator> <connect from_port="single" to_op="Extract Content (2)" to_port="document"/> <connect from_op="Extract Content (2)" from_port="document" to_port="output 1"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:documents_to_data" compatibility="5.1.002" expanded="true" height="76" name="Documents to Data (2)" width="90" x="315" y="30"> <parameter key="text_attribute" value="content"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.008" expanded="true" height="76" name="Select Attributes" width="90" x="450" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|content|URL"/> </operator> <connect from_port="in 1" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_op="Loop Collection" to_port="collection"/> <connect from_op="Loop Collection" from_port="output 1" to_op="Documents to Data (2)" to_port="documents 1"/> <connect from_op="Documents to Data (2)" from_port="example set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Get news pages" from_port="out 1" to_op="Extract content" to_port="in 1"/> <connect from_op="Extract content" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <process expanded="true" height="386" width="413"> <operator activated="true" class="text:process_document_from_file" compatibility="5.1.002" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="30"> <list key="text_directories"> <parameter key="ResultDir" value="C:\Users\Andrea\Desktop\Result"/> </list> <process expanded="true" height="415" width="346"> <operator activated="true" class="web:extract_html_text_content" compatibility="5.1.002" expanded="true" height="60" name="Extract Content" width="90" x="45" y="30"/> <operator activated="true" class="text:transform_cases" compatibility="5.1.002" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="120"/> <operator activated="true" class="text:replace_tokens" compatibility="5.1.002" expanded="true" height="60" name="Replace Tokens" width="90" x="45" y="255"> <list key="replace_dictionary"> <parameter key="e-mail" value="email"/> </list> </operator> <operator activated="true" class="text:tokenize" compatibility="5.1.002" expanded="true" height="60" name="Tokenize" width="90" x="112" y="345"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.1.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="246" y="255"/> <operator activated="true" class="text:stem_snowball" compatibility="5.1.002" expanded="true" height="60" name="Stem (Snowball)" width="90" x="179" y="120"/> <operator activated="true" class="text:filter_by_length" compatibility="5.1.002" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="246" y="30"> <parameter key="min_chars" value="2"/> <parameter key="max_chars" value="999"/> </operator> <connect from_port="document" to_op="Extract Content" to_port="document"/> <connect from_op="Extract Content" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Replace Tokens" to_port="document"/> <connect from_op="Replace Tokens" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Stem (Snowball)" to_port="document"/> <connect from_op="Stem (Snowball)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.008" expanded="true" height="76" name="Select Attributes" width="90" x="45" y="210"> <parameter key="attribute_filter_type" value="no_missing_values"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="set_role" compatibility="5.1.008" expanded="true" height="76" name="Set Role" width="90" x="179" y="255"> <parameter key="name" value="label"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="x_validation" compatibility="5.1.008" expanded="true" height="130" name="Validation" width="90" x="246" y="30"> <parameter key="number_of_validations" value="5"/> <process expanded="true" height="347" width="145"> <operator activated="true" class="k_nn" compatibility="5.1.008" expanded="true" height="76" name="k-NN" width="90" x="45" y="120"> <parameter key="k" value="3"/> <parameter key="weighted_vote" value="true"/> <parameter key="measure_types" value="NumericalMeasures"/> <parameter key="numerical_measure" value="CosineSimilarity"/> </operator> <connect from_port="training" to_op="k-NN" to_port="training set"/> <connect from_op="k-NN" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="347" width="145"> <operator activated="true" class="apply_model" compatibility="5.1.008" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.1.008" expanded="true" height="76" name="Performance" width="90" x="60" y="141"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> <portSpacing port="sink_averagable 3" spacing="0"/> </process> </operator> <connect from_op="Process Documents from Files" from_port="example set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_port="result 1"/> <connect from_op="Validation" from_port="training" to_port="result 2"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 3"/> <connect from_op="Validation" from_port="averagable 2" to_port="result 4"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> <portSpacing port="sink_result 5" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <process expanded="true" height="386" width="413"> <operator activated="true" class="text:process_document_from_file" compatibility="5.1.002" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="30"> <list key="text_directories"> <parameter key="EconomyAndPolitic" value="C:\Users\Andrea\Desktop\Result\EconomyAndPolitic"/> <parameter key="Sport" value="C:\Users\Andrea\Desktop\Result\Sport"/> </list> <parameter key="use_file_extension_as_type" value="false"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true" height="415" width="346"> <operator activated="true" class="web:extract_html_text_content" compatibility="5.1.002" expanded="true" height="60" name="Extract Content" width="90" x="45" y="30"/> <operator activated="true" class="text:transform_cases" compatibility="5.1.002" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="120"/> <operator activated="true" class="text:replace_tokens" compatibility="5.1.002" expanded="true" height="60" name="Replace Tokens" width="90" x="45" y="255"> <list key="replace_dictionary"> <parameter key="e-mail" value="email"/> </list> </operator> <operator activated="true" class="text:tokenize" compatibility="5.1.002" expanded="true" height="60" name="Tokenize" width="90" x="179" y="345"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.1.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="246" y="255"/> <operator activated="true" class="text:stem_snowball" compatibility="5.1.002" expanded="true" height="60" name="Stem (Snowball)" width="90" x="179" y="120"/> <operator activated="true" class="text:filter_by_length" compatibility="5.1.002" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="246" y="30"> <parameter key="min_chars" value="2"/> <parameter key="max_chars" value="999"/> </operator> <connect from_port="document" to_op="Extract Content" to_port="document"/> <connect from_op="Extract Content" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Replace Tokens" to_port="document"/> <connect from_op="Replace Tokens" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Stem (Snowball)" to_port="document"/> <connect from_op="Stem (Snowball)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.008" expanded="true" height="76" name="Select Attributes" width="90" x="45" y="210"> <parameter key="attribute_filter_type" value="no_missing_values"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="set_role" compatibility="5.1.008" expanded="true" height="76" name="Set Role" width="90" x="179" y="255"> <parameter key="name" value="label"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="x_validation" compatibility="5.1.008" expanded="true" height="130" name="Validation" width="90" x="246" y="30"> <parameter key="number_of_validations" value="2"/> <process expanded="true" height="347" width="145"> <operator activated="true" class="k_nn" compatibility="5.1.008" expanded="true" height="76" name="k-NN" width="90" x="45" y="75"> <parameter key="k" value="2"/> <parameter key="weighted_vote" value="true"/> <parameter key="measure_types" value="NumericalMeasures"/> <parameter key="numerical_measure" value="CosineSimilarity"/> </operator> <connect from_port="training" to_op="k-NN" to_port="training set"/> <connect from_op="k-NN" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="347" width="145"> <operator activated="true" class="apply_model" compatibility="5.1.008" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> <parameter key="create_view" value="true"/> </operator> <operator activated="true" class="performance" compatibility="5.1.008" expanded="true" height="76" name="Performance" width="90" x="60" y="141"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> <portSpacing port="sink_averagable 3" spacing="0"/> </process> </operator> <connect from_op="Process Documents from Files" from_port="example set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_port="result 1"/> <connect from_op="Validation" from_port="training" to_port="result 2"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 3"/> <connect from_op="Validation" from_port="averagable 2" to_port="result 4"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> <portSpacing port="sink_result 5" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.009" expanded="true" name="Process"> <process expanded="true" height="627" width="614"> <operator activated="true" class="text:process_document_from_file" compatibility="5.1.001" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="30"> <list key="text_directories"> <parameter key="EconomyAndPolitic" value="C:\Users\Andrea\Desktop\Result\EconomyAndPolitic"/> <parameter key="Sport" value="C:\Users\Andrea\Desktop\Result\Sport"/> </list> <parameter key="use_file_extension_as_type" value="false"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true" height="415" width="346"> <operator activated="true" class="web:extract_html_text_content" compatibility="5.1.002" expanded="true" height="60" name="Extract Content" width="90" x="45" y="30"/> <operator activated="true" class="text:transform_cases" compatibility="5.1.001" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="120"/> <operator activated="true" class="text:replace_tokens" compatibility="5.1.001" expanded="true" height="60" name="Replace Tokens" width="90" x="45" y="255"> <list key="replace_dictionary"> <parameter key="e-mail" value="email"/> </list> </operator> <operator activated="true" class="text:tokenize" compatibility="5.1.001" expanded="true" height="60" name="Tokenize" width="90" x="179" y="345"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.1.001" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="246" y="255"/> <operator activated="true" class="text:stem_snowball" compatibility="5.1.001" expanded="true" height="60" name="Stem (Snowball)" width="90" x="179" y="120"/> <operator activated="true" class="text:filter_by_length" compatibility="5.1.001" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="246" y="30"> <parameter key="min_chars" value="2"/> <parameter key="max_chars" value="999"/> </operator> <connect from_port="document" to_op="Extract Content" to_port="document"/> <connect from_op="Extract Content" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Replace Tokens" to_port="document"/> <connect from_op="Replace Tokens" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Stem (Snowball)" to_port="document"/> <connect from_op="Stem (Snowball)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.009" expanded="true" height="76" name="Select Attributes" width="90" x="45" y="210"> <parameter key="attribute_filter_type" value="no_missing_values"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="set_role" compatibility="5.1.009" expanded="true" height="76" name="Set Role" width="90" x="179" y="210"> <parameter key="name" value="label"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="x_validation" compatibility="5.1.009" expanded="true" height="130" name="Validation" width="90" x="246" y="30"> <parameter key="number_of_validations" value="2"/> <process expanded="true" height="347" width="145"> <operator activated="true" class="k_nn" compatibility="5.1.009" expanded="true" height="76" name="k-NN" width="90" x="45" y="75"> <parameter key="k" value="2"/> <parameter key="weighted_vote" value="true"/> <parameter key="measure_types" value="NumericalMeasures"/> <parameter key="numerical_measure" value="CosineSimilarity"/> </operator> <connect from_port="training" to_op="k-NN" to_port="training set"/> <connect from_op="k-NN" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="347" width="145"> <operator activated="true" class="apply_model" compatibility="5.1.009" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> <parameter key="create_view" value="true"/> </operator> <operator activated="true" class="performance" compatibility="5.1.009" expanded="true" height="76" name="Performance" width="90" x="60" y="141"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> <portSpacing port="sink_averagable 3" spacing="0"/> </process> </operator> <operator activated="true" class="text:process_document_from_file" compatibility="5.1.001" expanded="true" height="76" name="Process Documents from Files (2)" width="90" x="45" y="390"> <list key="text_directories"> <parameter key="unclassified" value="C:\Users\Andrea\Desktop\Result\TestFiles"/> </list> <parameter key="use_file_extension_as_type" value="false"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true" height="607" width="763"> <operator activated="true" class="web:extract_html_text_content" compatibility="5.1.002" expanded="true" height="60" name="Extract Content (2)" width="90" x="45" y="30"/> <operator activated="true" class="text:transform_cases" compatibility="5.1.001" expanded="true" height="60" name="Transform Cases (2)" width="90" x="180" y="30"/> <operator activated="true" class="text:replace_tokens" compatibility="5.1.001" expanded="true" height="60" name="Replace Tokens (2)" width="90" x="315" y="30"> <list key="replace_dictionary"> <parameter key="e-mail" value="email"/> </list> </operator> <operator activated="true" class="text:tokenize" compatibility="5.1.001" expanded="true" height="60" name="Tokenize (2)" width="90" x="450" y="30"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.1.001" expanded="true" height="60" name="Filter Stopwords (2)" width="90" x="585" y="30"/> <operator activated="true" class="text:stem_snowball" compatibility="5.1.001" expanded="true" height="60" name="Stem (2)" width="90" x="45" y="120"/> <operator activated="true" class="text:filter_by_length" compatibility="5.1.001" expanded="true" height="60" name="Filter Tokens (2)" width="90" x="380" y="75"> <parameter key="min_chars" value="2"/> <parameter key="max_chars" value="999"/> </operator> <connect from_port="document" to_op="Extract Content (2)" to_port="document"/> <connect from_op="Extract Content (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/> <connect from_op="Transform Cases (2)" from_port="document" to_op="Replace Tokens (2)" to_port="document"/> <connect from_op="Replace Tokens (2)" from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/> <connect from_op="Filter Stopwords (2)" from_port="document" to_op="Stem (2)" to_port="document"/> <connect from_op="Stem (2)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/> <connect from_op="Filter Tokens (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.009" expanded="true" height="76" name="Select Attributes (2)" width="90" x="179" y="390"> <parameter key="attribute_filter_type" value="no_missing_values"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="apply_model" compatibility="5.1.009" expanded="true" height="76" name="Apply Model (2)" width="90" x="447" y="210"> <list key="application_parameters"/> </operator> <connect from_op="Process Documents from Files" from_port="example set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Validation" from_port="training" to_port="result 1"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 2"/> <connect from_op="Validation" from_port="averagable 2" to_port="result 3"/> <connect from_op="Process Documents from Files (2)" from_port="example set" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_port="result 4"/> <connect from_op="Apply Model (2)" from_port="model" to_port="result 5"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="126"/> <portSpacing port="sink_result 5" spacing="0"/> <portSpacing port="sink_result 6" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <process expanded="true" height="505" width="681"> <operator activated="true" class="subprocess" compatibility="5.1.008" expanded="true" height="76" name="Get news pages" width="90" x="45" y="120"> <process expanded="true" height="580" width="667"> <operator activated="true" class="web:get_webpage" compatibility="5.1.002" expanded="true" height="60" name="Get Page" width="90" x="45" y="30"> <parameter key="url" value="http://www.repubblica.it"/> <parameter key="random_user_agent" value="true"/> <list key="query_parameters"/> </operator> <operator activated="true" class="text:cut_document" compatibility="5.1.002" expanded="true" height="60" name="Cut Document" width="90" x="112" y="120"> <parameter key="query_type" value="XPath"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"> <parameter key="article-link" value="//h:h3/h:a[contains(@href,'news')]/@href"/> </list> <list key="namespaces"/> <list key="index_queries"/> <process expanded="true" height="355" width="497"> <connect from_port="segment" to_port="document 1"/> <portSpacing port="source_segment" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:documents_to_data" compatibility="5.1.002" expanded="true" height="76" name="Documents to Data" width="90" x="246" y="75"> <parameter key="text_attribute" value="news-links"/> <parameter key="add_meta_information" value="false"/> </operator> <operator activated="true" class="web:retrieve_webpages" compatibility="5.1.002" expanded="true" height="60" name="Get Pages" width="90" x="380" y="165"> <parameter key="link_attribute" value="news-links"/> <parameter key="page_attribute" value="content"/> <parameter key="random_user_agent" value="true"/> </operator> <connect from_op="Get Page" from_port="output" to_op="Cut Document" to_port="document"/> <connect from_op="Cut Document" from_port="documents" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Documents to Data" from_port="example set" to_op="Get Pages" to_port="Example Set"/> <connect from_op="Get Pages" from_port="Example Set" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="subprocess" compatibility="5.1.008" expanded="true" height="112" name="Extract content" width="90" x="246" y="120"> <process expanded="true" height="598" width="614"> <operator activated="true" class="text:data_to_documents" compatibility="5.1.002" expanded="true" height="60" name="Data to Documents" width="90" x="45" y="30"> <parameter key="select_attributes_and_weights" value="true"/> <list key="specify_weights"> <parameter key="content" value="1.0"/> </list> </operator> <operator activated="true" class="loop_collection" compatibility="5.1.008" expanded="true" height="76" name="Loop Collection" width="90" x="112" y="210"> <process expanded="true" height="373" width="602"> <operator activated="true" class="web:extract_html_text_content" compatibility="5.1.002" expanded="true" height="60" name="Extract Content (2)" width="90" x="265" y="30"> <parameter key="minimum_text_block_length" value="10"/> </operator> <connect from_port="single" to_op="Extract Content (2)" to_port="document"/> <connect from_op="Extract Content (2)" from_port="document" to_port="output 1"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:documents_to_data" compatibility="5.1.002" expanded="true" height="76" name="Documents to Data (2)" width="90" x="179" y="30"> <parameter key="text_attribute" value="content"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.008" expanded="true" height="76" name="Select Attributes" width="90" x="313" y="165"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|content"/> </operator> <operator activated="true" class="loop_examples" compatibility="5.1.008" expanded="true" height="94" name="Loop Examples" width="90" x="479" y="217"> <parameter key="iteration_macro" value="testo"/> <process expanded="true" height="367" width="700"> <operator activated="true" class="write_special" compatibility="5.1.008" expanded="true" height="60" name="Write Special Format" width="90" x="279" y="178"> <parameter key="example_set_file" value="C:\Users\Andrea\Desktop\Result\Articles.txt"/> <parameter key="special_format" value="$a"/> </operator> <connect from_port="example set" to_op="Write Special Format" to_port="input"/> <connect from_op="Write Special Format" from_port="through" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_port="in 1" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_op="Loop Collection" to_port="collection"/> <connect from_op="Loop Collection" from_port="output 1" to_op="Documents to Data (2)" to_port="documents 1"/> <connect from_op="Documents to Data (2)" from_port="example set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="out 1"/> <connect from_op="Select Attributes" from_port="original" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="example set" to_port="out 2"/> <connect from_op="Loop Examples" from_port="output 1" to_port="out 3"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> <portSpacing port="sink_out 3" spacing="0"/> <portSpacing port="sink_out 4" spacing="0"/> </process> </operator> <connect from_op="Get news pages" from_port="out 1" to_op="Extract content" to_port="in 1"/> <connect from_op="Extract content" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
colo wrote:Hi Andrea,inside "Loop Examples" you could do something like the solution described here: http://rapid-i.com/rapidforum/index.php/topic,4055.0.htmlYou can extract the URL you want to use as file name in a similar way using macros. But you have to ensure that there aren't symbols inside the URL string that are invalid within filenames.I think you might simplify the chain "Data to Documents" - "Loop Collection" - "Documents to Data" by using a single "Process Documents from Data" instead. This will not affect functionality but require two operators less.RegardsMatthias
