<process version="7.0.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.0.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="7.0.001" expanded="true" height="68" name="Generate Data" width="90" x="112" y="34"> <parameter key="number_examples" value="1000000"/> <parameter key="number_of_attributes" value="2"/> </operator> <operator activated="true" class="numerical_to_binominal" compatibility="7.0.001" expanded="true" height="82" name="Numerical to Binominal" width="90" x="313" y="34"> <parameter key="min" value="-10.0"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Numerical to Binominal" to_port="example set input"/> <connect from_op="Numerical to Binominal" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
