Hi All,
I am reading data from SQL Server 2005 Database with "Read Database" operator with query and I am giving it for "Outlier Detection (Distance based)" operator. The Query retrieving around 9000 examples and 2 attributes. TRAN_ID and TRAN_AMT. I am using TRAN_AMT for Outlier Detection.
But It is giving
"out of memory problem saying that This process need more memory than available.............". I am using Windows XP 32 bit. 2 GB Ram. In RM's system window it is Inittially at the staring time of the process it showing Available: 1GB, and MAX:1 GB.
After some time, when the process is going on all the memory used and giving out of memory problem.
Here is the code
<process version="5.1.006">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Process">
<process expanded="true" height="564" width="746">
<operator activated="true" class="read_database" compatibility="5.1.006" expanded="true" height="60" name="Read Database" width="90" x="45" y="210">
<parameter key="connection" value="anki"/>
<parameter key="query" value="SELECT "TRAN_ID", "TRAN_AMT" FROM "CUST_TRANDbk" WHERE CUST_ID=319021623"/>
<parameter key="table_name" value="ACCOUNTS"/>
<enumeration key="parameters"/>
<operator activated="true" class="set_role" compatibility="5.1.006" expanded="true" height="76" name="Set Role" width="90" x="246" y="210">
<parameter key="name" value="TRAN_AMT"/>
<list key="set_additional_roles">
<parameter key="TRAN_ID" value="id"/>
<parameter key="TRAN_AMT" value="regular"/>
</list>
<operator activated="true" class="detect_outlier_distances" compatibility="5.1.006" expanded="true" height="76" name="Detect Outlier (Distances)" width="90" x="380" y="120">
<parameter key="number_of_outliers" value="900"/>
<connect from_op="Read Database" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Detect Outlier (Distances)" to_port="example set input"/>
<connect from_op="Detect Outlier (Distances)" from_port="example set output" to_port="result 1"/>
</process>
</process>
Is there any other way to solve this problem? Whether I need to take higher configuration system?
Thank you for your answers.
Yours
Anki
