<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <process expanded="true" height="674" width="919"> <operator activated="true" class="retrieve" compatibility="5.1.008" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="loop_attribute_subsets" compatibility="5.1.008" expanded="true" height="60" name="Loop Subsets" width="90" x="179" y="30"> <process expanded="true" height="674" width="919"> <operator activated="true" class="x_validation" compatibility="5.1.008" expanded="true" height="112" name="Validation" width="90" x="45" y="30"> <process expanded="true" height="674" width="434"> <operator activated="true" class="decision_tree" compatibility="5.1.008" expanded="true" height="76" name="Decision Tree" width="90" x="45" y="30"/> <connect from_port="training" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="674" width="434"> <operator activated="true" class="apply_model" compatibility="5.1.008" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.1.008" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.1.008" expanded="true" height="76" name="Log" width="90" x="179" y="30"> <list key="log"> <parameter key="used_attributes" value="operator.Loop Subsets.value.feature_names"/> <parameter key="used_number" value="operator.Loop Subsets.value.feature_number"/> <parameter key="performance" value="operator.Validation.value.performance"/> </list> </operator> <connect from_port="example set" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <portSpacing port="source_example set" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Loop Subsets" to_port="example set"/> <connect from_op="Loop Subsets" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Hi Ingo (yes, I learn quickly)
Using this logger in a Optimize Selection (Brute Force) does not give proper values for the feature_names value... Or so it seems. Only one shows up. Is that maybe because of the parallel execution?
