<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <process expanded="true" height="566" width="748"> <operator activated="true" class="subprocess" compatibility="5.1.008" expanded="true" height="76" name="Subprocess" width="90" x="45" y="30"> <process expanded="true" height="607" width="705"> <operator activated="true" class="generate_nominal_data" compatibility="5.1.008" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"> <parameter key="number_examples" value="1"/> <parameter key="number_of_attributes" value="2"/> </operator> <operator activated="true" class="set_data" compatibility="5.1.008" expanded="true" height="76" name="Set Data" width="90" x="180" y="30"> <parameter key="example_index" value="1"/> <parameter key="attribute_name" value="att1"/> <parameter key="value" value="12"/> <list key="additional_values"/> </operator> <operator activated="true" class="set_data" compatibility="5.1.008" expanded="true" height="76" name="Set Data (2)" width="90" x="315" y="30"> <parameter key="example_index" value="1"/> <parameter key="attribute_name" value="att2"/> <parameter key="value" value="I love data mining"/> <list key="additional_values"/> </operator> <operator activated="true" class="rename" compatibility="5.1.008" expanded="true" height="76" name="Rename" width="90" x="450" y="30"> <parameter key="old_name" value="att1"/> <parameter key="new_name" value="ID"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="rename" compatibility="5.1.008" expanded="true" height="76" name="Rename (2)" width="90" x="585" y="30"> <parameter key="old_name" value="att2"/> <parameter key="new_name" value="Text"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.008" expanded="true" height="76" name="Select Attributes" width="90" x="45" y="120"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Set Data" to_port="example set input"/> <connect from_op="Set Data" from_port="example set output" to_op="Set Data (2)" to_port="example set input"/> <connect from_op="Set Data (2)" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="90"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="split" compatibility="5.1.008" expanded="true" height="76" name="Split" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Text"/> <parameter key="split_pattern" value="\s"/> </operator> <operator activated="true" class="de_pivot" compatibility="5.1.008" expanded="true" height="76" name="De-Pivot" width="90" x="313" y="30"> <list key="attribute_name"> <parameter key="text" value="Text_\d+"/> </list> <parameter key="index_attribute" value="index"/> </operator> <connect from_op="Subprocess" from_port="out 1" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_op="De-Pivot" to_port="example set input"/> <connect from_op="De-Pivot" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
