<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Process"> <process expanded="true" height="386" width="748"> <operator activated="true" class="text:read_document" compatibility="5.1.001" expanded="true" height="60" name="Read Document" width="90" x="45" y="30"> <parameter key="file" value="C:\Users\Home\Desktop\info.txt"/> </operator> <operator activated="true" class="web:crawl_web" compatibility="5.1.000" expanded="true" height="60" name="Crawl Web" width="90" x="447" y="165"> <list key="crawling_rules"/> <parameter key="output_dir" value="C:\Users\Home\Desktop\DATA"/> <parameter key="extension" value="html"/> <parameter key="user_agent" value="Mozilla/5.0 (Windows NT 6.1; rv:5.0) Gecko/20100101 Firefox/5.0"/> </operator> <operator activated="true" class="text:documents_to_data" compatibility="5.1.001" expanded="true" height="76" name="Documents to Data" width="90" x="179" y="30"> <parameter key="text_attribute" value="string"/> <parameter key="add_meta_information" value="false"/> <parameter key="datamanagement" value="double_array"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.1.006" expanded="true" height="60" name="Extract Macro" width="90" x="313" y="30"> <parameter key="macro" value="macro"/> </operator> <operator activated="true" class="loop_examples" compatibility="5.1.006" expanded="true" height="76" name="Loop Examples" width="90" x="447" y="30"> <parameter key="iteration_macro" value="macro"/> <process expanded="true" height="380" width="691"> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Read Document" from_port="output" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Documents to Data" from_port="example set" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Loop Examples" to_port="example set"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="198"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Process"> <process expanded="true" height="380" width="691"> <operator activated="true" class="read_excel" compatibility="5.1.006" expanded="true" height="60" name="Read Excel" width="90" x="45" y="165"> <parameter key="excel_file" value="C:\Users\Home\Desktop\test.xls"/> <parameter key="imported_cell_range" value="A1:A2"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> <parameter key="1" value="Name"/> </list> <parameter key="locale" value="English"/> <list key="data_set_meta_data_information"> <parameter key="0" value="http://www\.google\.de/.true.attribute_value.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> </operator> <operator activated="true" class="loop_examples" compatibility="5.1.006" expanded="true" height="76" name="Loop Examples" width="90" x="246" y="165"> <parameter key="iteration_macro" value="url"/> <process expanded="true" height="398" width="709"> <operator activated="true" class="extract_macro" compatibility="5.1.006" expanded="true" height="60" name="Extract Macro" width="90" x="179" y="30"> <parameter key="macro" value="extract"/> </operator> <operator activated="true" class="web:retrieve_webpages" compatibility="5.1.000" expanded="true" height="60" name="Get Pages" width="90" x="380" y="30"> <parameter key="link_attribute" value="%{extract}"/> <parameter key="user_agent" value="Mozilla/5.0 (Windows NT 6.1; rv:5.0) Gecko/20100101 Firefox/5.0"/> <parameter key="accept_cookies" value="all"/> </operator> <connect from_port="example set" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Get Pages" to_port="Example Set"/> <connect from_op="Get Pages" from_port="Example Set" to_port="example set"/> <portSpacing port="source_example set" spacing="36"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Read Excel" from_port="output" to_op="Loop Examples" to_port="example set"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <process expanded="true" height="380" width="691"> <operator activated="false" class="read_excel" compatibility="5.1.008" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30"> <parameter key="excel_file" value="C:\Users\Home\Desktop\test.xls"/> <parameter key="imported_cell_range" value="A1:A2"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> <parameter key="1" value="Name"/> </list> <parameter key="locale" value="English"/> <list key="data_set_meta_data_information"> <parameter key="0" value="http://www\.google\.de/.true.attribute_value.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> </operator> <operator activated="true" class="subprocess" compatibility="5.1.008" expanded="true" height="76" name="Subprocess" width="90" x="45" y="120"> <process expanded="true" height="607" width="773"> <operator activated="true" class="generate_nominal_data" compatibility="5.1.008" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"> <parameter key="number_examples" value="3"/> <parameter key="number_of_attributes" value="1"/> <parameter key="number_of_values" value="1"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.008" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="att1"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="rename" compatibility="5.1.008" expanded="true" height="76" name="Rename" width="90" x="179" y="165"> <parameter key="old_name" value="att1"/> <parameter key="new_name" value="url"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="set_data" compatibility="5.1.008" expanded="true" height="76" name="Set Data" width="90" x="313" y="165"> <parameter key="example_index" value="1"/> <parameter key="attribute_name" value="url"/> <parameter key="value" value="http://google.com"/> <list key="additional_values"/> </operator> <operator activated="true" class="set_data" compatibility="5.1.008" expanded="true" height="76" name="Set Data (2)" width="90" x="447" y="165"> <parameter key="example_index" value="2"/> <parameter key="attribute_name" value="url"/> <parameter key="value" value="http://microsoft.com"/> <list key="additional_values"/> </operator> <operator activated="true" class="set_data" compatibility="5.1.008" expanded="true" height="76" name="Set Data (3)" width="90" x="581" y="165"> <parameter key="example_index" value="3"/> <parameter key="attribute_name" value="url"/> <parameter key="value" value="http://mozilla.org"/> <list key="additional_values"/> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Set Data" to_port="example set input"/> <connect from_op="Set Data" from_port="example set output" to_op="Set Data (2)" to_port="example set input"/> <connect from_op="Set Data (2)" from_port="example set output" to_op="Set Data (3)" to_port="example set input"/> <connect from_op="Set Data (3)" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_examples" compatibility="5.1.008" expanded="true" height="94" name="Loop Examples" width="90" x="246" y="30"> <process expanded="true" height="398" width="709"> <operator activated="true" class="delay" compatibility="5.1.008" expanded="true" height="76" name="Delay" width="90" x="45" y="30"> <parameter key="delay" value="fixed"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.1.008" expanded="true" height="60" name="Extract Macro" width="90" x="179" y="30"> <parameter key="macro" value="website_url"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="url"/> <parameter key="example_index" value="%{example}"/> </operator> <operator activated="true" class="web:crawl_web" compatibility="5.1.000" expanded="true" height="60" name="Crawl Web" width="90" x="45" y="165"> <parameter key="url" value="%{website_url}"/> <list key="crawling_rules"/> <parameter key="max_pages" value="100"/> <parameter key="max_depth" value="1"/> <parameter key="domain" value="server"/> <parameter key="max_page_size" value="500"/> </operator> <connect from_port="example set" to_op="Delay" to_port="through 1"/> <connect from_op="Delay" from_port="through 1" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_port="example set"/> <connect from_op="Crawl Web" from_port="Example Set" to_port="output 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="5.1.008" expanded="true" height="76" name="Append" width="90" x="447" y="30"/> <connect from_op="Subprocess" from_port="out 1" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Process"> <process expanded="true" height="380" width="691"> <operator activated="false" class="read_excel" compatibility="5.1.006" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30"> <parameter key="excel_file" value="C:\Users\Home\Desktop\test.xls"/> <parameter key="imported_cell_range" value="A1:A2"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> <parameter key="1" value="Name"/> </list> <parameter key="locale" value="English"/> <list key="data_set_meta_data_information"> <parameter key="0" value="http://www\.google\.de/.true.attribute_value.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> </operator> <operator activated="true" class="subprocess" compatibility="5.1.006" expanded="true" height="76" name="Subprocess" width="90" x="45" y="120"> <process expanded="true" height="607" width="773"> <operator activated="true" class="generate_nominal_data" compatibility="5.1.006" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"> <parameter key="number_examples" value="3"/> <parameter key="number_of_attributes" value="1"/> <parameter key="number_of_values" value="1"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.006" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="att1"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="rename" compatibility="5.1.006" expanded="true" height="76" name="Rename" width="90" x="179" y="165"> <parameter key="old_name" value="att1"/> <parameter key="new_name" value="url"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="set_data" compatibility="5.1.006" expanded="true" height="76" name="Set Data" width="90" x="313" y="165"> <parameter key="example_index" value="1"/> <parameter key="attribute_name" value="url"/> <parameter key="value" value="http://www.philosophischergarten.de/ "/> <list key="additional_values"/> </operator> <operator activated="true" class="set_data" compatibility="5.1.006" expanded="true" height="76" name="Set Data (2)" width="90" x="447" y="165"> <parameter key="example_index" value="2"/> <parameter key="attribute_name" value="url"/> <parameter key="value" value="http://www.ganuba.de/ "/> <list key="additional_values"/> </operator> <operator activated="true" class="set_data" compatibility="5.1.006" expanded="true" height="76" name="Set Data (3)" width="90" x="581" y="165"> <parameter key="example_index" value="3"/> <parameter key="attribute_name" value="url"/> <parameter key="value" value="http://www.stone.ag/jwa/de/home.jsp "/> <list key="additional_values"/> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Set Data" to_port="example set input"/> <connect from_op="Set Data" from_port="example set output" to_op="Set Data (2)" to_port="example set input"/> <connect from_op="Set Data (2)" from_port="example set output" to_op="Set Data (3)" to_port="example set input"/> <connect from_op="Set Data (3)" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_examples" compatibility="5.1.006" expanded="true" height="94" name="Loop Examples" width="90" x="246" y="30"> <process expanded="true" height="398" width="709"> <operator activated="true" class="delay" compatibility="5.1.006" expanded="true" height="76" name="Delay" width="90" x="45" y="30"/> <operator activated="true" class="extract_macro" compatibility="5.1.006" expanded="true" height="60" name="Extract Macro" width="90" x="179" y="30"> <parameter key="macro" value="website_url"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="url"/> <parameter key="example_index" value="%{example}"/> </operator> <operator activated="true" class="web:crawl_web" compatibility="5.1.000" expanded="true" height="60" name="Crawl Web" width="90" x="45" y="165"> <parameter key="url" value="%{website_url}"/> <list key="crawling_rules"> <parameter key="follow_link_with_matching_url" value=".+imp.+"/> <parameter key="store_with_matching_url" value=".+imp.+"/> </list> <parameter key="output_dir" value="C:\Users\Home\Desktop\Sites"/> <parameter key="extension" value="html"/> <parameter key="max_pages" value="100"/> <parameter key="max_depth" value="1"/> <parameter key="domain" value="server"/> <parameter key="max_page_size" value="500"/> </operator> <connect from_port="example set" to_op="Delay" to_port="through 1"/> <connect from_op="Delay" from_port="through 1" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_port="example set"/> <connect from_op="Crawl Web" from_port="Example Set" to_port="output 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="5.1.006" expanded="true" height="76" name="Append" width="90" x="447" y="30"/> <connect from_op="Subprocess" from_port="out 1" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <process expanded="true" height="380" width="691"> <operator activated="false" class="read_excel" compatibility="5.1.008" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30"> <parameter key="excel_file" value="C:\Users\Home\Desktop\test.xls"/> <parameter key="imported_cell_range" value="A1:A2"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> <parameter key="1" value="Name"/> </list> <parameter key="locale" value="English"/> <list key="data_set_meta_data_information"> <parameter key="0" value="http://www\.google\.de/.true.attribute_value.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> </operator> <operator activated="true" class="subprocess" compatibility="5.1.008" expanded="true" height="76" name="Subprocess" width="90" x="45" y="120"> <process expanded="true" height="607" width="773"> <operator activated="true" class="generate_nominal_data" compatibility="5.1.008" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"> <parameter key="number_examples" value="3"/> <parameter key="number_of_attributes" value="1"/> <parameter key="number_of_values" value="1"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.008" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="att1"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="rename" compatibility="5.1.008" expanded="true" height="76" name="Rename" width="90" x="179" y="165"> <parameter key="old_name" value="att1"/> <parameter key="new_name" value="url"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="set_data" compatibility="5.1.008" expanded="true" height="76" name="Set Data" width="90" x="313" y="165"> <parameter key="example_index" value="1"/> <parameter key="attribute_name" value="url"/> <parameter key="value" value="http://www.philosophischergarten.de/ "/> <list key="additional_values"/> </operator> <operator activated="true" class="set_data" compatibility="5.1.008" expanded="true" height="76" name="Set Data (2)" width="90" x="447" y="165"> <parameter key="example_index" value="2"/> <parameter key="attribute_name" value="url"/> <parameter key="value" value="http://www.ganuba.de/ "/> <list key="additional_values"/> </operator> <operator activated="true" class="set_data" compatibility="5.1.008" expanded="true" height="76" name="Set Data (3)" width="90" x="581" y="165"> <parameter key="example_index" value="3"/> <parameter key="attribute_name" value="url"/> <parameter key="value" value="http://www.stone.ag/jwa/de/home.jsp "/> <list key="additional_values"/> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Set Data" to_port="example set input"/> <connect from_op="Set Data" from_port="example set output" to_op="Set Data (2)" to_port="example set input"/> <connect from_op="Set Data (2)" from_port="example set output" to_op="Set Data (3)" to_port="example set input"/> <connect from_op="Set Data (3)" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:generate_extract" compatibility="5.1.001" expanded="true" height="60" name="Generate Extract" width="90" x="179" y="120"> <parameter key="source_attribute" value="url"/> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"> <parameter key="url_domain" value="https?://(.*?)/"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> </operator> <operator activated="true" class="loop_examples" compatibility="5.1.008" expanded="true" height="94" name="Loop Examples" width="90" x="380" y="30"> <process expanded="true" height="398" width="709"> <operator activated="true" class="delay" compatibility="5.1.008" expanded="true" height="76" name="Delay" width="90" x="45" y="30"/> <operator activated="true" class="extract_macro" compatibility="5.1.008" expanded="true" height="60" name="Extract Macro" width="90" x="179" y="30"> <parameter key="macro" value="website_url"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="url"/> <parameter key="example_index" value="%{example}"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.1.008" expanded="true" height="60" name="Extract Macro (2)" width="90" x="313" y="30"> <parameter key="macro" value="domain"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="url_domain"/> <parameter key="example_index" value="%{example}"/> </operator> <operator activated="true" class="execute_program" compatibility="5.1.008" expanded="true" height="76" name="Execute Program" width="90" x="447" y="30"> <parameter key="command" value="cmd.exe /c "md C:\Users\Home\Desktop\Sites\%{domain}""/> </operator> <operator activated="true" class="web:crawl_web" compatibility="5.1.000" expanded="true" height="60" name="Crawl Web" width="90" x="45" y="120"> <parameter key="url" value="%{website_url}"/> <list key="crawling_rules"> <parameter key="follow_link_with_matching_url" value=".+imp.+"/> <parameter key="store_with_matching_url" value=".+imp.+"/> </list> <parameter key="output_dir" value="C:\Users\Home\Desktop\Sites\%{domain}"/> <parameter key="extension" value="html"/> <parameter key="max_pages" value="5"/> <parameter key="max_depth" value="1"/> <parameter key="domain" value="server"/> <parameter key="max_page_size" value="500"/> </operator> <connect from_port="example set" to_op="Delay" to_port="through 1"/> <connect from_op="Delay" from_port="through 1" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Extract Macro (2)" to_port="example set"/> <connect from_op="Extract Macro (2)" from_port="example set" to_op="Execute Program" to_port="through 1"/> <connect from_op="Execute Program" from_port="through 1" to_port="example set"/> <connect from_op="Crawl Web" from_port="Example Set" to_port="output 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="72"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="5.1.008" expanded="true" height="76" name="Append" width="90" x="514" y="30"/> <connect from_op="Subprocess" from_port="out 1" to_op="Generate Extract" to_port="Example Set"/> <connect from_op="Generate Extract" from_port="Example Set" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
https?://(.*?)(/|$)
