<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <parameter key="parallelize_main_process" value="true"/> <process expanded="true" height="359" width="681"> <operator activated="true" class="text:read_document" compatibility="5.1.001" expanded="true" height="60" name="Read Document" width="90" x="45" y="30"> <parameter key="file" value="C:\Users\?lkis_!!\Desktop\negative.txt"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.1.001" expanded="true" height="94" name="Process Documents" width="90" x="179" y="30"> <parameter key="create_word_vector" value="false"/> <parameter key="keep_text" value="true"/> <process expanded="true" height="607" width="773"> <operator activated="true" class="text:tokenize" compatibility="5.1.001" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/> <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.1.001" expanded="true" height="60" name="Filter Stopwords (Dictionary)" width="90" x="179" y="30"> <parameter key="file" value="C:\Users\?lkis_!!\Desktop\stopwords_greek.txt"/> </operator> <operator activated="true" class="text:write_document" compatibility="5.1.001" expanded="true" height="60" name="Write Document" width="90" x="313" y="30"> <parameter key="file" value="C:\Users\?lkis_!!\Desktop\result\???????????????????"/> </operator> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (Dictionary)" to_port="document"/> <connect from_op="Filter Stopwords (Dictionary)" from_port="document" to_op="Write Document" to_port="document"/> <connect from_op="Write Document" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Read Document" from_port="output" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
