Covariance Process Problems
swimguy112
I have been having problems with the covariance operator and I was hoping that someone might be able to help.
Here is an XML readout of what I am attempting to do:
<process version="5.1.006">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Process">
<process expanded="true" height="555" width="565">
<operator activated="true" breakpoints="after" class="generate_data" compatibility="5.1.006" expanded="true" height="60" name="Generate Data" width="90" x="112" y="75"/>
<operator activated="true" breakpoints="after" class="covariance_matrix" compatibility="5.1.006" expanded="true" height="76" name="Covariance Matrix" width="90" x="292" y="71"/>
<connect from_op="Generate Data" from_port="output" to_op="Covariance Matrix" to_port="example set"/>
<connect from_op="Covariance Matrix" from_port="covariance" to_port="result 1"/>
</process>
</process>
Before the process can finish I continually get a error message reading:
Process failed
The setup does not seem to contain any obvious errors, but you should check the log messages or activate the debug mode in the setting dialog in order to get more information about this problem.
Here is a readout of what the log file says:
Jun 22, 2011 7:25:24 PM INFO: Generate Data: Breakpoint reached.
Jun 22, 2011 7:25:33 PM SEVERE: Process failed: operator cannot be executed (6). Check the log messages...
Jun 22, 2011 7:25:33 PM SEVERE: Here: Process[1] (Process)
subprocess 'Main Process'
+- Generate Data[1] (Generate Data)
==> +- Covariance Matrix[1] (Covariance Matrix)
Jun 22, 2011 7:25:33 PM SEVERE: java.lang.ArrayIndexOutOfBoundsException: 6
I'm familiar with out of bound errors but I do not know how to correct them in rapidminer.
Any advice would be greatly appreciated. Thanks!
Marco_Boeck
thanks for the report, the bug has been fixed
Your process should work after the next release.
Marco
