Hello all,
I am doing conversion job (LS Dyna to Optistruct). There are more than 400 components and 200000 elements. I converted all of them and gave run. Results were matched.
Then i have tried to renumber all the elements and components in that model. But after that it will give an error says
' *** ERROR # 1461 *** in the input data:
Card 'LOAD' is not allowed for this subcase type.'
I defined Global case control card with below parameters.
ANALYSIS = MODE
FREQ = EIGRL
LOAD = SPC
SPC = SPC
If i delete this card it is running. I don't know what is the problem. I deleted loadsteps and control cards and created new loadsteps and control cards. But still it is giving same error.I except the solution for this problem
