<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Root"> <process expanded="true" height="584" width="815"> <operator activated="true" class="retrieve" compatibility="5.1.008" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="decision_tree" compatibility="5.1.008" expanded="true" height="76" name="DecisionTree" width="90" x="179" y="30"/> <operator activated="true" class="reporting:generate_report" compatibility="5.0.002" expanded="true" height="76" name="Generate Report" width="90" x="313" y="30"> <parameter key="report_name" value="Hello Report!"/> <parameter key="format" value="HTML"/> <parameter key="repository_entry" value="//LocalRepository/t"/> <parameter key="html_output_directory" value="C:\Users\username\Desktop"/> <parameter key="pdf_output_file" value="C:\Users\username\Desktop\report.pdf"/> <parameter key="pdf_template_file" value="no file selected"/> <parameter key="image_template_file" value="no file selected"/> <parameter key="section_one_font" value="courier"/> <parameter key="section_two_font" value="courier"/> <parameter key="section_three_font" value="courier"/> <parameter key="section_four_font" value="courier"/> <parameter key="section_five_font" value="courier"/> <parameter key="text_content_font" value="courier"/> </operator> <operator activated="true" class="reporting:report" compatibility="5.0.002" expanded="true" height="60" name="Report" width="90" x="447" y="30"> <parameter key="report_name" value="Hello Report!"/> <parameter key="report_item_header" value="Decision Tree Image"/> <parameter key="specified" value="true"/> <parameter key="reportable_type" value="Decision Tree"/> <parameter key="renderer_name" value="Graph View"/> <list key="parameters"> <parameter key="layout" value="Tree"/> <parameter key="show_node_labels" value="true"/> <parameter key="show_edge_labels" value="true"/> </list> </operator> <connect from_op="Retrieve" from_port="output" to_op="DecisionTree" to_port="training set"/> <connect from_op="DecisionTree" from_port="model" to_op="Generate Report" to_port="through 1"/> <connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/> <connect from_op="Report" from_port="reportable out" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Could you plaese help me to export the full image of decision tree. I have installed the reporting extension. But then how does it help to export the full image of Decision tree ?
