9 character problem
barisyildirimmm
hi,
i want to add data to postgresql from excel...but i cant do that because one column adding as 'name' format...but i send it 'text' format...and for example my name is Barış YILDIRIM , it says that ;
Exception: com.rapidminer.operator.UserError
Message: Database error occurred: Attribute isim contains values with length >9 which is the maximum length for columns of SQL type name
Stack trace:
com.rapidminer.operator.io.DatabaseExampleSetWriter.write(DatabaseExampleSetWriter.java:82)
com.rapidminer.operator.io.DatabaseExampleSetWriter.write(DatabaseExampleSetWriter.java:60)
com.rapidminer.operator.io.AbstractWriter.doWork(AbstractWriter.java:67)
com.rapidminer.operator.Operator.execute(Operator.java:764)
com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51)
com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:709)
com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:368)
com.rapidminer.Process.run(Process.java:854)
com.rapidminer.Process.run(Process.java:761)
com.rapidminer.Process.run(Process.java:756)
com.rapidminer.Process.run(Process.java:746)
com.rapidminer.gui.ProcessThread.run(ProcessThread.java:65)
Cause
Exception: java.sql.SQLException
Message: Attribute isim contains values with length >9 which is the maximum length for columns of SQL type name
Stack trace:
com.rapidminer.tools.jdbc.StatementCreator.makeColumnCreator(StatementCreator.java:253)
com.rapidminer.tools.jdbc.StatementCreator.makeTableCreator(StatementCreator.java:183)
com.rapidminer.tools.jdbc.DatabaseHandler.createTable(DatabaseHandler.java:476)
com.rapidminer.operator.io.DatabaseExampleSetWriter.write(DatabaseExampleSetWriter.java:79)
Marco_Boeck
please do not cross-post your problem around various boards, if anything it will delay answers.
However I don't quite understand your problem, could you be more clear about it and post your process xml as well?
Marco
barisyildirimmm
Sorry about other topic...
i am using another program because of this problem...so the problem disappeared...
Thanks...
chrismxnr
I had exactly the same problem here today. It didn't want to add two of my nominal attributes in the ExampleSet to a table in PostgreSQL (the same exception).
I got it fixed with integrating the newest version of the PostgreSQL JDBC driver into RapidMiner (9.1-901, JDBC4).
My database version is PostgreSQL 8.4.8.
So maybe it would be a good idea to update the integrated PostgreSQL JDBC-driver with the next update? For me it seems to be a bug in the old one.
Best regards,
Chris
Marco_Boeck
indeed, we will do that.
Marco
