I have tried to code a simple java program that read a csv file, create a naive bayes model and save the output model. But the compiler give me this error:
com.rapidminer.operator.OperatorCreationException: No operator description object given for 'com.rapidminer.operator.io.CSVDataReader'
	at com.rapidminer.tools.OperatorService.createOperator(OperatorService.java:583)
	at rapidProcess.exampleProcess.main(exampleProcess.java:24)
But in the API the CSVDataReader is included in com.rapidminer.operator.io so I don't understand the error.
This is the very simple code. Thanks in advance.
package rapidProcess;
import com.rapidminer.RapidMiner;
import com.rapidminer.operator.Operator;
import com.rapidminer.operator.OperatorCreationException;
import com.rapidminer.operator.OperatorException;
import com.rapidminer.operator.io.CSVDataReader;
import com.rapidminer.operator.io.ModelWriter;
import com.rapidminer.operator.learner.bayes.NaiveBayes;
import com.rapidminer.tools.OperatorService;
import com.rapidminer.Process;
public class exampleProcess {
	 * @param args
	public static void main(String[] args) {
		RapidMiner.init();
		try {
			/* Reading Data */
			Operator trainingDataReader = OperatorService.createOperator(CSVDataReader.class);
			trainingDataReader.setParameter("csv_file", "train.csv");
			/* Classifier */
			Operator bayesClassifier = OperatorService.createOperator(NaiveBayes.class);
			/* Save model */
			Operator modelWriter = OperatorService.createOperator(ModelWriter.class);
			modelWriter.setParameter("model_file", "prova_model");
			trainingDataReader.getOutputPorts().getPortByName("output").connectTo(bayesClassifier.getInputPorts().getPortByName("training set"));
			bayesClassifier.getOutputPorts().getPortByName("model").connectTo(modelWriter.getInputPorts().getPortByName("input"));
			Process process = new Process();
			process.getRootOperator().getSubprocess(0).addOperator(bayesClassifier);
			process.run();
		} catch (OperatorCreationException e) {
			// TODO Auto-generated catch block
			e.printStackTrace();
		} catch (OperatorException e) {
