Hi All,
I would like to run 10 replicates of 10-fold cross validation.
The loop & average operator will perform 10 iterations but will the XValidation operator perform
10 independent splitting & stratification procedures? Because it is useless if my workflow loop 10 times with the same subsets of cross validation.
What is the different with or without local random seed for XValidation operator? I would like to reproduce the results but I;m curious since I got the same results without using local random seed after few runs of the workflow.
<process version="5.1.006">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Process">
<process expanded="true" height="640" width="614">
<operator activated="true" class="retrieve" compatibility="5.1.006" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30">
<parameter key="repository_entry" value="//Samples/data/Iris"/>
<operator activated="true" class="normalize" compatibility="5.1.006" expanded="true" height="94" name="Normalize" width="90" x="179" y="30">
<parameter key="method" value="range transformation"/>
<parameter key="min" value="-1.0"/>
<operator activated="true" class="optimize_parameters_grid" compatibility="5.1.006" expanded="true" height="112" name="Optimize Parameters (Grid)" width="90" x="313" y="30">
<list key="parameters">
<parameter key="SVM.C" value="[0.2;20000;10;linear]"/>
<parameter key="SVM.gamma" value="[2E-15;2E-3;10;linear]"/>
</list>
<process expanded="true" height="623" width="692">
<operator activated="true" class="loop_and_average" compatibility="5.1.006" expanded="true" height="76" name="Loop and Average" width="90" x="112" y="30">
<process expanded="true" height="622" width="692">
<operator activated="true" class="x_validation" compatibility="5.1.006" expanded="true" height="112" name="Validation" width="90" x="179" y="30">
<description>A cross-validation evaluating a decision tree model.</description>
<parameter key="local_random_seed" value="197"/>
<process expanded="true" height="622" width="330">
<operator activated="true" class="support_vector_machine_libsvm" compatibility="5.1.006" expanded="true" height="76" name="SVM" width="90" x="120" y="30">
<list key="class_weights"/>
<connect from_port="training" to_op="SVM" to_port="training set"/>
<connect from_op="SVM" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.1.006" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance" compatibility="5.1.006" expanded="true" height="76" name="Performance" width="90" x="187" y="30"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="true" class="log" compatibility="5.1.006" expanded="true" height="76" name="Log" width="90" x="313" y="30">
<list key="log">
<parameter key="C" value="operator.SVM.parameter.C"/>
<parameter key="Gamma" value="operator.SVM.parameter.gamma"/>
<parameter key="Performance" value="operator.Performance.value.performance"/>
</list>
<connect from_port="in 1" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/>
<connect from_op="Log" from_port="through 1" to_port="averagable 1"/>
<portSpacing port="source_in 2" spacing="0"/>
</process>
<connect from_port="input 1" to_op="Loop and Average" to_port="in 1"/>
<connect from_op="Loop and Average" from_port="averagable 1" to_port="performance"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
<connect from_op="Retrieve" from_port="output" to_op="Normalize" to_port="example set input"/>
<connect from_op="Normalize" from_port="example set output" to_op="Optimize Parameters (Grid)" to_port="input 1"/>
<connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/>
<connect from_op="Optimize Parameters (Grid)" from_port="parameter" to_port="result 2"/>
<connect from_op="Optimize Parameters (Grid)" from_port="result 1" to_port="result 3"/>
</process>
</process>
