<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <process expanded="true" height="409" width="678"> <operator activated="true" class="retrieve" compatibility="5.1.008" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="x_validation" compatibility="5.1.008" expanded="true" height="112" name="k-fold" width="90" x="179" y="30"> <process expanded="true" height="541" width="433"> <operator activated="true" class="weka:W-ReliefFAttributeEval" compatibility="5.1.000" expanded="true" height="76" name="W-ReliefFAttributeEval (2)" width="90" x="45" y="30"/> <operator activated="true" class="select_by_weights" compatibility="5.1.008" expanded="true" height="94" name="Select by Weights (2)" width="90" x="180" y="30"> <parameter key="weight_relation" value="top k"/> <parameter key="k" value="5"/> </operator> <operator activated="true" class="naive_bayes" compatibility="5.1.008" expanded="true" height="76" name="Naive Bayes" width="90" x="313" y="30"/> <connect from_port="training" to_op="W-ReliefFAttributeEval (2)" to_port="example set"/> <connect from_op="W-ReliefFAttributeEval (2)" from_port="weights" to_op="Select by Weights (2)" to_port="weights"/> <connect from_op="W-ReliefFAttributeEval (2)" from_port="example set" to_op="Select by Weights (2)" to_port="example set input"/> <connect from_op="Select by Weights (2)" from_port="example set output" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Select by Weights (2)" from_port="weights" to_port="through 1"/> <connect from_op="Naive Bayes" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> <portSpacing port="sink_through 2" spacing="0"/> </process> <process expanded="true" height="541" width="433"> <operator activated="true" class="select_by_weights" compatibility="5.1.008" expanded="true" height="94" name="Select by Weights (3)" width="90" x="45" y="75"> <parameter key="weight_relation" value="top k"/> <parameter key="k" value="5"/> </operator> <operator activated="true" class="apply_model" compatibility="5.1.008" expanded="true" height="76" name="-1 Folds Model" width="90" x="179" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_classification" compatibility="5.1.008" expanded="true" height="76" name="Accuracy Fold" width="90" x="313" y="30"> <list key="class_weights"/> </operator> <connect from_port="model" to_op="-1 Folds Model" to_port="model"/> <connect from_port="test set" to_op="Select by Weights (3)" to_port="example set input"/> <connect from_port="through 1" to_op="Select by Weights (3)" to_port="weights"/> <connect from_op="Select by Weights (3)" from_port="example set output" to_op="-1 Folds Model" to_port="unlabelled data"/> <connect from_op="-1 Folds Model" from_port="labelled data" to_op="Accuracy Fold" to_port="labelled data"/> <connect from_op="Accuracy Fold" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="source_through 2" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="k-fold" to_port="training"/> <connect from_op="k-fold" from_port="averagable 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="72"/> <portSpacing port="sink_result 2" spacing="18"/> </process> </operator></process>
