Hi, everyone,
I am using rapidminer to do sentiment analysis according to the following website.
http://kmandcomputing.blogspot.com/2008/06/opinion-mining-with-rapidminer-quick.html.I am using the latest version of rapidminer to do it.
Here is the codes:
<process version="5.1.004">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.004" expanded="true" name="Process">
<process expanded="true" height="242" width="346">
<operator activated="true" class="text:process_document_from_file" compatibility="5.1.001" expanded="true" height="76" name="Process Documents from Files" width="90" x="69" y="106">
<list key="text_directories">
<parameter key="positive" value="C:\Documents and Settings\sunny\Desktop\mix20_rand700_tokens\tokens\pos"/>
<parameter key="negative" value="C:\Documents and Settings\sunny\Desktop\mix20_rand700_tokens\tokens\neg"/>
</list>
<parameter key="datamanagement" value="short_sparse_array"/>
<process expanded="true" height="517" width="709">
<operator activated="true" class="text:tokenize" compatibility="5.1.001" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.1.001" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="45" y="165"/>
<operator activated="true" class="text:stem_porter" compatibility="5.1.001" expanded="true" height="60" name="Stem (Porter)" width="90" x="45" y="300"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.1.001" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="313" y="75"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Porter)" to_port="document"/>
<connect from_op="Stem (Porter)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="x_validation" compatibility="5.1.004" expanded="true" height="112" name="Validation" width="90" x="246" y="75">
<process expanded="true" height="517" width="329">
<operator activated="true" class="support_vector_machine_linear" compatibility="5.1.004" expanded="true" height="76" name="SVM (Linear)" width="90" x="89" y="49"/>
<connect from_port="training" to_op="SVM (Linear)" to_port="training set"/>
<connect from_op="SVM (Linear)" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.1.004" expanded="true" height="76" name="Apply Model" width="90" x="100" y="45">
<operator activated="true" class="performance" compatibility="5.1.004" expanded="true" height="76" name="Performance" width="90" x="45" y="165"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_op="Process Documents from Files" from_port="example set" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_port="result 1"/>
<connect from_op="Validation" from_port="training" to_port="result 2"/>
</process>
</process>
The data set comes from this website:
http://www.cs.cornell.edu/People/pabo/movie-review-data/I downloaded polarity dataset v0.9 to use sentiment analysis.
However, the simulating process is more than 2 days and still continuing. What wrong is it? I cannot understand why the process is running for more than 2 days? Is it common? Look forward to hearing from you soon.
Many thanks,
Sunny
